    Veteran Member Three Rings quattro_silver's Avatar
    Jun 18 2008
    Chicago, IL
    Broken Bleed Valve - Anyone try the repair kits?
    I was doing a brake fluid change over the weekend (car is at 215k) and the front-driver side caliper bleeder valve
    snapped off at the threads (tiny bit sticking out of the hole on caliper) while trying to loosen it. It was seized and
    almost stripped, I also didn't use a torch so unfortunately it snapped.
    My question now is how to fix this. Right now it's not a huge issue because it never loosened the bolt so I just
    never bled that corner but in the future I would like to fix it. Has anyone used a bleed valve repair kit?
    I saw this online and thought it might do the trick if I brought it to a shop to tap.
    http://shop.advanceautoparts.com/p/d...3960/5012856-P
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    E-Codes + DDM 55w 6k
    SRP pedals
    Hawk HPS + Adams slotted
    Kicker CompVT
    Jun 18 2008
    Chicago, IL
    I also found these I could use if I can get the old one out.
    http://www.speedbleeder.zoovy.com/pr...d-Bleeder.html
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Jul 04 2012
    Woodbridge, VA
    Same thing happened to me. They are just sitting in my shed for scrap metal. But let me know if you come up with a solution.
    Jun 18 2008
    Chicago, IL
    Quote Originally Posted by vavJETTAw36 View Post
    Buddy who's a mechanic says I can just give him the caliper and his easy out will get it out and put back a stock bleeder valve. I'll let you know how it goes.
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    SRP pedals
    Kicker CompVT
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by quattro_silver View Post
    Thanks man.
