Results 1 to 13 of 13
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    RS5 - swapped pads on rotors that had 10k miles on them...now "rumble" when slowing
    Hey guys,
    As we all know, Rs5 brakes are just about the most annoying thing on the planet. I recently swapped to hawk pads after my factory ones went out. Mind you, this is my third set of brakes in 22k miles. 2 were done under warranty - now I'm on my own.
    Well, now after about 500 miles on the hawks, the car seems to be humming/vibrating as I come to stop....20-5 mph it makes a hum from the right. I guess this is the pad not seeding with the rotor? Any other ideas?
    I'm about to just rip all that shit out, get the ECS 380mm rotor "stage 2" upgrade and start from scratch. Does anyone have this kit?
    Thanks,
    Chris
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Established Member Two Rings Ixxe's Avatar
    Sep 29 2014
    Estonia
    Sorry for a bit of side topic, but might be a future rs5 owner.
    Does rs5 have problems with ceramic brakes too or just the regular ones?
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Chris, have you been doing a lot of stop start slow moving traffic? It may be worth running the bedding in process again with some high speed braking to see if it clears up.
    It seems a bit shitty to replace the brakes out of your own pocket just to get them working but Audi really dropped a ball with cost cutting in development of these wave brake rotors so you aren't left with much choice. The ECS kit looks like a wise investment, they certainly look like they will perform.
    Ixxe, none that I can see or have read reports on, they seem pretty reliable.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    You probably have uneven deposits on your rotors from the OEM pads. You should really start over with fresh rotors and pads. Your pads may be messed up now. Another option is to put on an aggressive track pad for a while that will scrape off all the deposits and then put on the Hawks.
    I thought about the Stage 2 kit, but then went with the full floating wave ECS rotors. The stage 2 rotors are not full floating. They are semi floating like the OEM rotors. But, I also installed the stainless steel brake lines and upgraded the fluid.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Established Member Two Rings HamadAJ's Avatar
    Aug 26 2015
    Abu Dhabi
    Quote Originally Posted by chrissurfr View Post
    Hey guys,
    Thanks,
    Chris
    Hey Chris,
    I have ECS 380mm rotor stage 2 brake upgrade with 6000 miles on it and it works perfectly fine. I had the same issue, where the pads would get shaven so fast and alot of wobbling and shacking under braking. If you want a quick and "relatively" cheap solution, i would pull the trigger. But if it was up to me I would save some big bucks and go for the cermaic rotors that fit directly on the OEM calipers from RB performance or GMG, had I known about it earlier I would have gone for this option.
    Hamad,
    Here are the links to the ceramic rotors.
    http://www.racingbrake.com/RB-CCM-X-...ont-p/2c81.htm
    http://www.gmgracing.com/store/2013/...sport-kit.html
    Apr 26 2005
    Houston
    thanks for the replies, gents.
    What is the benefit of "true float" and why would I want that over a bigger rotor?
    Hamad - would you mind posting a pic of the 380s behind your wheels?
    If I have to do this AGAIN - I would at least feel better about with a little upgrade lol....
    • eCode headlights
    • Eventuri intake
    Jan 07 2013
    Tru float rotors ensure that the rotor is always centered under the caliper regardless of lateral thermal expansion or slightly off center mounting. The calipers on the RS5 are fixed, so they can't center themselves over the rotor. Instead a tru float rotor moves on the lateral axes and centers itself. This ensures even pad wear on both sides and optimum contact of the pads at all times, resulting in better and more consistent brake feel and improved stopping power. I do frequent 100+ miles canyon runs where my brakes get hot, so proper handling of thermal expansion was high on my priority list.
    EDIT: I thought ECS actually had a good description of the benefits. Here they are:
    Tru-Float design:
    • The full float design allows independent radial and lateral thermal expansion and movement. Both of these features reduce thermal stresses on the rotor due to uneven thermal loading under hard braking.
    • The full float design conducts less heat in to the bearings due to reduced contact area between the rotor and the hat, improving bearing life.
    • The radial expansion allows the ring to increase in diameter without being restrained by the hat, reducing the tendency to “cone” or distort toward the outer braking surface, improving pedal feel and pad wear characteristics
    • The lateral float capability allows the rotor to self-center between the pads, improving pad wear and reducing drag. It also reduces the effects of pad knock back, which is the tendency of the rotor to push the pistons back in to the calipers due to wheel bearing deflection under extreme loading, resulting in a soft pedal and inconsistent braking. Reducing or eliminating knock back by allowing the rotor to float and self-center results in a more consistent pedal feel and braking
    Veteran Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    Quote Originally Posted by Ixxe View Post
    Ceramics don't have this issue.
    Jan 07 2013
    Much smaller sample set, though. Not as many ceramic brakes in the wild. Also, having the standard brakes doesn't automatically mean you'll have these issues. The only "issue" I had was that the OEM pads only lasted 24k miles of pretty hard driving. I'm now at ~48k miles with the ECS rotors and Hawk pads and I still have 75% pad life left, so quite a significant difference and for less money, too. At that rate the cost of the ceramic brakes is not justified, IMO, unless you really spend a lot of time on the track.
    Apr 26 2005
    Houston
    Well....I bedded the living shit out of the brakes tonight....lets see how they feel tomorrow. Fingers crossed. If not...upgrade time.
    • eCode headlights
    • Eventuri intake
    Aug 26 2015
    Abu Dhabi
    Here a pic for ya, don't mind the scratched up alloygators . They look bigger than the OEM for sure.
    Jan 07 2013
    Quote Originally Posted by HamadAJ View Post
    Tru-float rotors for comparison:
    Apr 26 2005
    Houston
    thank you for the pics....alloygators hahaha
    both look better than OEM for sure. It seems like the brake bedding helped. I'm going to do it one more time tonight to see if I can get it 100% gone...my brakes were smoking last night when I was done lol
    • eCode headlights
    • Eventuri intake
