Results 1 to 40 of 40
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    ECS Tuning Smoked Headlight Marker Film Review
    I bought the smoked headlight marker film and while it's not perfect it does a great job for $20 instead of $900+ for Ecodes. The film goes on easy and peels off if you make a few corrections (several times). Here are some pics before and after.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Not bad for $20 and not needing to remove the headlights to take them apart or spend $1k on ecodes...looks like they should have gone a bit darker tho.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jul 04 2008
    York, PA
    Quote Originally Posted by BlownOne View Post
    Ill snap some daytime photos. The ones your seeing have my garage lights on which are super bright. The ambers are not as noticeable in normal lighting.
    Oct 02 2006
    Wadsworth,OH
    Thanks for posting up your pics and the review!
    Jason
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Thanks for the post as well. Anyone have a silver, blue or other non-black/daytona that might be able to snap a pic outside? Curious as to how it sits next to a brighter paint. Thanks!
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by 4Rings3Liters View Post
    Gotcha. Well the second angle looks darker than the first, but the lighting probably just gives the appearance of it being lighter than it is.
    Oct 02 2006
    Wadsworth,OH
    Here's some of our pics from when we installed them on our vehicles.
    Jason
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Thanks for posting.
    @ECS, looks like the orange still is seen from a head on view?
    Any chance of making them wider to cover it a bit more? Also will smoke or charcoal be available, or just gunsmoke? Thanks.
    Oct 02 2006
    Wadsworth,OH
    Yes some of the orange can still be seen from the front. Unfortunately due to the headlight being rounded and the reflector being thick you would need to cover much more of the headlight to completely cover all the orange from every angle. We looked into this, and have decided that the thickness we went with looks the cleanest from most angles.
    At the moment we do not have plans to offer them in darker shades, though if we see increasing demand it could be something we could offer.
    Jason
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    The amber is recessed in the headlight. Increasing the size to cover the front view would either unbalance the look, or may even cover up part of the DRL.
    Speaking from experience, these covers are great and well worth the purchase, but are still simply a stepping stone to getting e-codes.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Jul 25 2010
    WI/IL
    Kind of what I was afraid of. Thanks for the replies.
    Oct 14 2012
    Empty...for now...
    SE PA
    If I were ECS or another company with adequate resources, I would be looking into making a production run of clear side reflectors either in the US-spec 'dimpled' texture or in the E-code style with the horizontal lines. I have to imagine that with the right production quantity, the margin made on those would be more than on a set of actual E-code headlights. In a world of $75 'Supercharged' badges, people would spend upwards of $100 on a pair of clear corner reflectors.
    SOLD 2015 Daytona Gray S4
    Oct 02 2006
    Wadsworth,OH
    That sounds like a good idea in theory. But it would require you to disassembled your headlight. I can't see the majority of people feeling comfortable with this. Not to mention if your reseal isn't perfect you'll get condensation. There's definitely a lot of risk involved which I don't think most would want to take. Don't get me wrong I know there's those out there that are more than capable of performing such mods, but it's not the majority. This also limits your targeted market too.
    Jason
    Apr 25 2016
    Anchorage
    What's the lifetime expectancy on these? Have you put them through automatic car washes or hit them with a high pressure washer?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by mike907 View Post
    I would expect them to have the same life expectancy as any other Lamin-X product. I've ran Lamin-X yellow fog light covers on my personal vehicle for years. You shouldn't have any issue with running your vehicle through an auto car wash with them on.
    As for a pressure washer if I were you I would use my best discretion, likely don't need to hit your headlights full blast from a short distance.
    Jason
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    I bit the bullet and just ordered this
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Not a fan.
    Does it throw any codes?
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Quote Originally Posted by Pared View Post
    Not a fan.
    Lol, it goes on the headlight
    Mar 30 2016
    West palm beach, Florida
    Anyone got them on the b8?
    Oct 31 2015
    So is this road legal in Canada? I think the headlight turning lamp needs to be Amber so not sure how this affects it.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Chibo View Post
    I would double check with your local laws prior to ordering if you have any doubt. It's also not a permanent solution.
    Jason
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Jason
    I'd be ALL over this if you could make them in all black!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Jul 07 2014
    Calgary, AB, Canada
    Do you mean turn signal lights? Because that's not being covered by this.
    2013 S5 6MT Phantom Black Pearl, Unitronics Stage 2+, AWE Touring /w res downpipes, KW V1, Eurocode Intake
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Already have xpel on my headlights...has anyone applied lamin-x over xpel? I would rather not remove the xpel for install in case I ever decide to remove the lamin-x on a future date.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Oct 31 2015
    Quote Originally Posted by Tangerined View Post
    Sorry meant reflectors.
    Mar 21 2015
    Quote Originally Posted by Powderhound View Post
    I'm in the same boat. I thought about cutting the xpel to the curve of the laminx.
    Jul 04 2008
    York, PA
    Here are some more pics. I think for the price these clean up the front nicely. Excuse the filth, she needs a bath.
    Oct 02 2006
    Wadsworth,OH
    Thanks for posting the pics! I definitely agree! It's so simple to install and can definitely enhance the look.
    Jason
    Mar 20 2015
    McKinney,TX
    anyone have a video of these with the turn signals on? Particularly at night
    I like the look but don't want to "delete" the turn signals
    Jun 22 2016
    West Chester, PA > Toronto, Canada
    Thank you for putting this up. I've been planning to write one but was lazy. I got a pair of those smoked markers as well. Along with these smoked ones, I got the yellow laminx for fog lamps as well...both from ECS Tuning (thanks Jason!).
    While I admit that the headlight marker could have been a bit darker, I am, honestly, more satisfied than disappointed. For $20, its bang for the buck!
    Current: 2022 A6 Allroad Mythos Black Technik | Air Suspension | Leather Package | Dual Pane Glass | Dad Mobile
    Previous: 2016 S4 Sepang Blue Premium+ Build Thread
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    Grab a heat gun, and dedicate a day to do them proper.
    Sent from my SM-G930T using Audizine mobile app
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Jul 04 2008
    York, PA
    Quote Originally Posted by AvusPdx View Post
    A day to install these? It took me 5 minutes...
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    He's saying proper like split them and wrap reflector then reseal.
    I did mine and no issues with fogging and no orange is visible. Took maybe 3 hours, while drinking and other bullshitting with friends. Would say a 2out of 10 difficulty
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Veteran Member Three Rings Game's Avatar
    Sep 18 2016
    Chicago
    Quote Originally Posted by tar View Post
    While the install may be a 2/10, the nerve-racking feeling of taking apart your 1k headlight and putting it in an oven is a 9/10.
    2013 Phantom Black Pearl S5 - 6MT -- Sports Diff | B&O | MMI
    APR Stage 1 | KW V2 coilovers | AWE touring exhaust | ECS Luft-Technik intake | CR-15 | replica RS5 grill | Enlaes CF rear spoiler | 15% Pinnacle ceramic tint | Maxton Design Lip-Kit | Rohana RFX11 wheels | ECS Rear Diffuser
    Past - 07 E92 335i - 6 MT
    Jan 17 2015
    Portland, OR
    I meant opening your head lights and wrapping the amber or replace them with clear.
    Jul 07 2009
    Socal/IE
    Heat gun and correct plastic pry tools.
    Not really stressful at all. A 2nd person helps alot plus I've done it a few times on other platforms.
    Sent from my VS987 using Tapatalk
    Jul 04 2008
    York, PA
    Gotcha, yeah I don't see myself baking my stock headlights. A $20 sticker suits my needs. I've never had someone come up to me and say what an ugly car your headlight has the reflector in it!
    Established Member Two Rings khahn's Avatar
    Jun 12 2016
    Decatur, tx
    Does anyone have the ECS part number for the marker covers?
    Jun 22 2016
    Here are a couple of pictures with the smoked ambers and yellow fog lamp laminx.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by khahn View Post
    Click HERE
    Jason
