Results 1 to 10 of 10
    Apr 26 2016
    VA
    2000 Audi S4 EPL Stage 3 - Needs Turbos/Possibly just a WG adjustment
    I have decided to sell my S4. The car has a clean VA title, clean carfax, and no accidents. The engine was replaced under factory warranty @60k, 01E was rebuilt @140k, now @155k miles.
    Borg Warner K04 Turbos
    SRM V3 Side Mount Intercoolers
    Integrated Engineering ICM Delete Kit/FSI Coils
    EPL Stage 3 Fuel Kit and Dyno Tune
    Bosch EV14 52lb Injectors
    Bosch 85mm MAF
    Bosch 710n Diverter Valves
    034 Throttle Body Boot
    AR Design 3" V-Band Down Pipes and High Flow Race Cats both Ceramic Coated (made in Denver, CO)
    EGT delete
    AWE Twin 1 Catback Exhaust
    (Sound is unbelievable at WOT)
    034 Street Motor Mount
    034 Snub Mount
    AWE DTS w/ Updated Polyurethane Mount
    ECS Tuning Ultimate Timing Belt Kit w/ Gates Kevlar Racing Belt
    Auxiliary Fan w/ Toggle Switch
    Rebuilt 01E w/ New Sychros, 1-2, and 3-4 Shift Collars
    Southbend Stage IV Clutch Kit
    034 Stainless Braided Slave Cylinder Line
    Tein Coilovers
    12 Piece Control Arm Kit
    New OE Lucas Front Left and Both Rear Calipers
    Stoptech Slotted Cryo Treated Front
    Rotors
    Recently Replaced OE Rear Rotors
    Hawk HPS pads
    Michelin A/S 3 Tires
    Some recent maintenance:
    Radiator
    N75
    Rear Wheel Bearings
    Speed Sensor
    Hella Oil Level Sensor
    Hood Latch and Lock Assembly
    Water Pump/New Gates Racing TB
    Timing Chain
    Valve Cover Gaskets
    Replaced Locking Pump
    Rear Differential Fluid Changed
    In January the water pump started leaking so it was replaced along with a new timing belt. The drivers side timing chain and locking pump were also replaced at that time ($2200 service in total).
    Current issues:
    I thought I had an exhaust leak but it turns out the leak is coming from the passenger side wastegate. This was confirmed by NGP racing, I can provide the invoice. The wastegates are adjustable but if the adjustment dosent fix the problem the turbos will have to be replaced. The car has been parked since March but I start it every weekend and let it warm up. Sometimes I take it down the street to get groceries.
    The wheels could also be resprayed. The front bumper is in bad shape and needs to be replaced.
    I have spent a lot of time and money on this car trying to keep it good shape. I thought at one point that I would keep this car forever but I just don't have the funds right now. I am looking for $5000. My loss your gain.
    Jul 03 2016
    Virginia
    I live in Va txt 7579697681 if you end up parting out the car dude.
    Lemme know
    Active Member Two Rings OllieOxenFree's Avatar
    Jul 06 2016
    Lisbon Ohio
    Seriously tho. What a price. GLWS
    Apr 26 2016
    VA
    Twozerotwo 34one 744four for faster response
    Aug 24 2014
    Newport Beach, CA
    What a deal, what leads you to believe the turbos or wastegate settings might be bad?
    2024 M3 Comp xDrive
    Apr 26 2016
    VA
    January/Feb I felt big power loss @wot, I thought it could be a big leak because the exhaust sound was pretty bad. Checked exhaust, disconnected/reconnected vbands no change. Took car to shop, was told WG was not closing.
    Veteran Member Three Rings ruiz's Avatar
    Apr 07 2009
    B5 bi-turbo avants
    MD
    Do you have receipts for any of the maintenance/mods you've done to the car? Nice Ferrari
    Apr 26 2016
    VA
    Yeah I have a folder of invoices, i tried to save everything
    Apr 26 2016
    VA
    Bump
    Apr 26 2016
    VA
    SOLD
