Results 1 to 8 of 8
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    Engine Warning - new to me
    Just started the S6 and as I was pulling away I got a warning that says - maximum engine RPM 4000. And now the actual redline starts at the 4 on the tach.
    No other warning lights at all, never had an issue but did have new transmission software update last Wednesday so I am thinking it is related.
    Car drives absolutely normal other than having a redline at 4K.
    Will scan later but since I am not at home anyone ever have this happen before or hear of it?
    Appreciate it.
    May 16 2008
    WA
    "high" oil pressure switch, seems to come up a lot, not sure if it applies to the S6 or just the A7/A6
    http://www.audizine.com/forum/showth...s-quot-2012-A7
    Google "S6 maximum engine RPM 4000"
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    Quote Originally Posted by Black3.2 View Post
    Appreciate it.
    would bet money it is your cam adjuster got stuck
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Sep 05 2015
    Nashville
    I had the same issue. Audi replaced the cam shaft sensor. The error came back. Audi recommended replacing the cam shaft adjusters on both the intake and exhaust side. It took them a week to get the car finished. I believe mine was a P0218 code.
    Established Member Two Rings Mdavis1722's Avatar
    Jul 12 2015
    I am having the same issue now and Audi is replacing the cam shaft adjusters. @Phi399 Did the problem ever return? I am about to be out of warranty and thinking about dumping my S6 for something else.
    Senior Member Two Rings schaNYC's Avatar
    Jun 06 2016
    I got a EPC light with this same msg about limiting to 4K rpm. Shortly after I got at CEL to go with it. Dealer said it was a intake manifold issue. Had to drive a 2.0T Q5 for 3 weeks while car in the shop waiting for new manifolds to arrive from Germany. I have <30k miles on car, stock.
    Jul 12 2015
    I am in a A6 2.0T going on two weeks.
    Apr 09 2008
    Austalia
    happened to me, it was the intake manifold flap sensor.
    B7 RS4 Cab APR Supercharger
    C7.5 RS6
    C7 S6 - Revo, Super Sprint Exhaust - Sold
    S5 - 1740 Stage 3 with all the supporting mods - Sold
