Results 1 to 9 of 9
    Jan 15 2012
    NEPA
    Steering problem after rack replacement.
    Just changed the steering rack in my '96 with a rack I pulled from a '99 (guy said it was fine last he drove it). Everything went smoothly, flushed and bled the system thoroughly, everything sounds normal. However, it's steering hard as hell now. Honestly feels like I don't have power steering. The only noticeable difference between the racks was the lack of the dampener on the newer one, but I've heard that shouldn't be an issue. Any insight to this problem would be great. I was hoping to get an alignment tomorrow and be done with this, but it can't really be driven the way it is.
    1996 Audi A4 aka Moneypit
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Hows the power steering belt?
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Jan 15 2012
    NEPA
    Quote Originally Posted by RENOxDECEPTION View Post
    Didn't seem to have any problems with stiff steering prior to the replacement, except when the fluid was low. The rack used to leak pretty bad, thus the need for replacement. I'm thinking it's possibly the pump. I haven't checked the belt though.
    Dec 10 2013
    Borden, Ontario, Canada
    Hard steering would indicate the pump is done, if the rack is confirmed good.
    If you take the cap off the power steering res while running, is there any flow?
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jan 15 2012
    NEPA
    Quote Originally Posted by Bordom View Post
    Just went out to check it, and there doesn't seem to be any kind of noticeable flow, the fluid seems relatively stagnant.
    Dec 10 2013
    Quote Originally Posted by Knikkz31 View Post
    Is there any change when you get someone to turn the wheel while the car is running? If not, pump is dead.
    IG: 24_et
    Sold:
    RIP:
    Jan 15 2012
    NEPA
    Had someone turn the wheel at idle, no flow. If I rev it up to around 3k+, it starts to flow, and the steering gets a bit easier also.
    Dec 10 2013
    Definitely replace the pump now. Something must have happened to it during the bleeding process.
    IG: 24_et
    Sold:
    RIP:
    Jan 15 2012
    NEPA
    Just ordered one. Hopefully it'll fix my problem. Thanks for the help!
