As the title suggests I have a B6 2002 A4 1.8t (5 speed) with a full APR stage 3 built. The car should be pushing around 330hp at the crank, however being that my motor has 185k miles, I probably am not quite at that number. I bought the car 3 years ago, and have gotten used to the power, so now I NEED more.
The engine will need to be rebuilt/replaced soon, as well as the clutch. I want to be making around 450hp plus as the crank. What are my options? I am all about value, so although money isn't necessarily limited, I would like to keep the whole build cost with installation less than $4K if possible.
I was initially planning on doing the most obvious thing and dropping in a 2.7t from the b5 s4. However someone mentioned I could get a 3.0 block with a 2.8 head, and use the 2.7t hardware for turbo bolt ups. Is this a better route? If I do get a 2.7t what would be the needed turbos and supporting engine internal upgrades I would need in order to handle 450+hp?
Finally I found someone selling a fully built 2.7t motor with drivetrain. He wants $4500 for the full build, just curious if this is a decent deal, and or if I could replicate it for cheaper.
From the listing:
"This drive train came out of my totaled 2002 S4 Avant. Build was stage three / RS4 by Achtuning out of Seattle. Build of this APM code engine included Pauter Steel rods, Mahle RS4 spec pistons, Borg Warner RS4 spec K04 turbochargers, Bosch 52lbs injectors, K04 specific stainless downpipes, cat back stainless exhaust, ECU with matching software, RS4 spec clutch disc and pressure plate, solid 01E transmission (never owned or driven by fools so no issues with 1-2 shift collar), driveshaft, and rear differential. Build was done in a couple stages while there were 32K to 35K miles on the car. An offroad excursion totaled the car with just over 38K miles on it. I scrapped the chassis saving the drivetrain. I was planning a swap in to a B6 S4 cabriolet but just haven't been able to locate the right candidate. I am now working on another Audi project so this needs to find its way to the right buyer. Will drop right into any 2.7T application in the A6 Allroad C5 chassis, A4 S4 B5 chassis, or with just slightly more effort in to the A6 C6 or A4 S4 B6 cars. Engine is still bolted to the transaxle and dressed with all accessories and wiring harness, driveshaft and exhaust are long and awkward so plan your transport vehicle accordingly. Before you call and bug me about the price add up what it would cost to duplicate this collection of Audi parts goodness."
