Results 1 to 12 of 12
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Schwaben car ramp capacity question
    I have the 56" ramps and under each of the 4 pieces, it says 1,500 lb capacity. I'm not sure if that means that each piece supports that amount of weight, but according to the product specifications, it says "One set supports 3,000 lbs." I'm imagining they aren't implying "one set" to mean one side of the two ramps set, because otherwise that would imply that I would have needed to buy 2 sets to support the cars weight. Now, our A4s curb weight is at least 3,500 lbs. So my question is, is it safe to use these ramps on a car that weighs over the 3,000 lb capacity these ramps support?
    Sent from my VS987 using Tapatalk
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Mar 21 2015
    You're only using two so it won't be an issue. Half the car is on the ground in the rear.
    Aug 10 2011
    North Whittier
    Yeah that crossed my mind. I searched other ramps and the $40 rhino ramps support up to 12,000 lbs compared to these $240+ ramps that barely support one fourth of that.
    Anyone have a notion as to why the schwabens are so expensive for such low weight capacity?
    May 20 2010
    Quote Originally Posted by doowopaudi View Post
    Because it's ECS...?
    Aug 10 2011
    North Whittier
    Haha, good point, except I don't think they're made by ecs. Or are they?
    Is schwaben ecs' label?
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    I have the Rhino ramps not the "fancy" ECS ones. My ramps are used on every vehicle I own, including my 2011 GMC 1500 Crew 4wd and they haven't killed me yet. I would buy them again...oh yeah, I did. I have 2 pair
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Jan 01 2012
    2004 A4 Avant
    CO
    You'll be fine, as stated you're not gonna have the full weight of the car on them. And I always put jack stands under the car even when using ramps. Better safe than sorry.
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    Heres my take. Doesnt matter if its ECS, harbor freight or Online. Ramps are ramps for convenience. Always use extra support no matter what, jackstands, jack, or even a wheel underneath. I have schwaben ramps, i dont stress about the max capacity because i always have backup support. Its straight foolish to climb under a car with only ramps no matter what the brand. Same goes with a jack, never use just a jack but i think most of us know that much. Thats my 2.
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Because Schwaben. Tools for tool collectors, not gearheads... people that like to get ripped off building their "complete" tool warchest which they hardly ever actually use. Everything Schwaben is overpriced. From their overkill tool sets that include every bit you'll never use to their rebranded 5-piece plastic trim tool set which can be bought at Harbor Freight for half the price. It's the EXACT same set.
    Someone nerds to make a fake Schwaben tool commercial.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Aug 10 2011
    North Whittier
    Update:
    I used the schwaben ramps today for the first time to perform an oil change on an Infiniti g35 and they held up well. I liked that they are wide enough to accommodate wide wheels/tires and they raise the car 8" off the ground. I'm not sure on the exact physics on the weight displacement when it comes to supporting the front end of the car in these ramps (is it supporting exactly 50% of the gross vehicle weight?) but i did use my 3 ton capacity harbor freight jack stands as back up.
    PS. Im a huge harbor freight fan/customer.
    Feb 23 2010
    Austin, TX
    The change in height is marginal. Weight distribution will be nearly the same as when the wheels are on the ground. Approximately 55% I believe to the front wheels for a B8.
    Established Member Two Rings X Y Z's Avatar
    Mar 20 2013
    SM610, AE86, FJ60
    Portland, Oregon
    Brute Technologies also makes Race Ramps, quality but spendy...
