Results 1 to 4 of 4
    Veteran Member Four Rings vailshred's Avatar
    Aug 20 2011
    Arizona/Colorado
    Oil burning only under load, ideas?
    Yesterday I drove a B6 S4 up the hills here in Colorado. Motor just had chain service, new valve stem seals, headgaskets, and so on.
    Car is running fantastic besides a loose alternator wire that i will get to this week.
    I was climbing one of our mountain passes when I looked in rear view a d noticed that i was blowing smoke out exhaust. I slightly smelt the burning oil also. I was doing about 80 mph, 5th gear and 3700-4000 rpm.
    It was not constant. It would start smoking after carrying that speed for a few minutes. Then it would go away once i let off the gas and it would not come back for a few minutes. Zero smoke on flat groung driving, start up or heavy acceleration off the line.
    The car is all stock except for full catless miltek exhaust.
    Any ideas?
    Thanks in advance
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    PCV valve?
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Quote Originally Posted by QIKRNU View Post
    PCV valve?
    X2 or vaccum leak
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    sound like "pancake valve"
