Results 1 to 9 of 9
    Senior Member Three Rings AngryQ5's Avatar
    May 05 2013
    15 Kia Rio Lx DD audi q5 2.0
    ny
    Question about giovanni wheel fitment
    Hi guys i recently got into an accident and cracked wheel.
    Was thinking of getting a cheap set of wheels. Giovanni 20x10 40 offset.
    272000032436
    Link to ebay .
    Would this give me good clearance with 295 tires? Was really diggin the looks of beefy 295.
    I have a 2.0 q5 2013. Thank you guys... wheel noob here haha
    Sent from my SM-N900V using Tapatalk
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Those won't work without spacers. Their offset it too high. If you're planning on running 295's, I would suggest 12-15mm spacers. The problem comes from the clearance of the front spindle or "steering knuckle." I have ET+30 with 295/21's, and there is no more than 4mm clearance. The ECS 12.5 should be perfect, but it depends on the tire as well, since they all vary a little in actual dimensions.
    May 05 2013
    ny
    Quote Originally Posted by SQive View Post
    Thank you so if i didnt want to go with spacers but still 20x10 W 295 tires what offset should i get ?
    Ty ty
    Apr 26 2014
    DFW
    Between 25 & 30, depending on the actual tire size.
    Tire manufacturers aren't that accurate, so different ones can range +/-5mm.
    What I did, was to get my wheels in ET+30, and then mounted a 295 for fitment testing.
    I expected to need something like 3-5mm spacers, but I got lucky.
    They fit perfect without any rub or poke.
    Of course, 25's would be safe with all 295's.
    May 05 2013
    ny
    Ok i see so 25 offset would be the target if not spacers. Thank you bro
    20x10 +25 295 got it
    May 05 2013
    ny
    Also how much do 295 tires run for? I have no clue what price im looking at thx
    Apr 26 2014
    DFW
    I pay a grand for a set of Vredestein Ultrac Vorti 295/35ZR21, shipped.
    Veteran Member Three Rings rusq5's Avatar
    Mar 27 2015
    SF Bay Area
    I'm running 20x10 ET30 with Potenza S001 295/35. Barely enough clearance in the front.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    May 05 2013
    ny
    Ok thank you guys
