    Active Member One Ring adinic2016's Avatar
    Jul 03 2016
    Italy
    Question AUDI A6 2016 facelift navigation - no touch - map version
    Hello, i have question regarding my navigation maps : i have version no. 8X0919884J - P32-50-15.03 / Software version : RMC_EU_P1432B. Is this the latest version and more important can i update myself with a newer version or this can only be done at the dealership? The maps are on a an sd card.
    Regarding the navigation model, this is navigation 3G or 3G+? (small screen, no touch).
    Thank you for your answers.
    Established Member Two Rings Stan77's Avatar
    Nov 24 2014
    Russian Empire
    Buon giorno. If you have google online, maps will updae autamatically. All MMI's comes without touchscreen, if you meant it. However i can't understand what kind of MMI you have , if you have NAV and small screen ) pics pls
    A7 '13 TDI, Revo Technik chip, 300hp/640Hm. - SOLD
    A7 '15 TDI Facelift, Revo Technik stage2, Straight pipe cat-back, RS7 intake, Wagner FMIC, Cete ASC Module, Alcon 6-pot 380x32mm BBK - 310hp/690Hm - Current
    Jul 03 2016
    Italy
    MMI NAVIGATION BASIC - no touch, no connect
    Hello. Thank your for your answer. Links to the pictures below:
    https://postimg.org/image/lg5eleyo7/
    https://postimg.org/image/sxem0mo7b
    https://postimg.org/image/vg0b1b9x
    https://postimg.org/image/58z45crnr
    Just to clarify : when I say no touch I don't mean no screen touch, but no touch near the gear selector (I only have numbers for the radio; by the way can these numbers be programmed to do something else? for exemple like the numbers on the BMW 5 series - menu shortcuts, fast calling etc).
    Have a good day!
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Quote Originally Posted by Stan77 View Post
    This is incorrect information. The underlying map database is what is controlling when using Google maps. If you're database is out of date and there is a new road along your route, Google maps will not use that new road if it isn't in the cars database. I know this first hand with a freeway exit/entrance that went in about 5 years ago in my city. Paying for data and using Google maps is NOT a workaround for an outdated database.
    To update the database requires a trip to the dealership as only they have the ability to activate the particular map set. I haven't seen a thread anywhere on someone successfully getting the maps to activate.
    Nov 24 2014
    Russian Empire
    Quote Originally Posted by SlickMachine View Post
    I don't know about pre-FL, cause my pre-FL was without Audi Connect option, but on FL with Audi connect option databases updating regullary just online. Just notice about "map updates avaible" popping on the screen and you're forwarding to select what area maps you want to update.
    To the topicstarter: Heh, on local market we have 3 options, base MMI radio without touch, nav etc, MMI 3G+ (MIB on FL) and MMI 3G+ (MIB) with Audi connect and google maps ) And yes, as it was noticed, you must visit dealer for database update if you haven't audi connect. However you should look for some non-official workshop who doing VAG service and updates, they can do it aswell. For example, maps update here in non-official workshop cost about 80-100eur.
