Results 1 to 12 of 12
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    K03 vs K04 Turbine Wheel Size
    I'm wondering if the turbine wheel between the k04 and the stock k03 is the same. Reason is, I have a good deal on a CHRA & Housing. What I would do to save costs is swap over the CHRA and compressor housing from the k04 onto the 2.0t stock exhaust manifold.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Aug 26 2005
    The K-03 and K-04 turbines are the same size, the turbine shaft is the same size also. The K-04 has a larger compressor impeller and housing.
    Vorsprung durch Technik
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Ko3 - 97-2000
    COMPRESSOR WHEEL
    Inducer: 33.6mm
    Exducer: 46mm
    Tip height: 3.7mm
    TURBINE WHEEL
    Inducer: 45mm
    Exducer: 38mm
    Tip height: 6.8mm
    Blades: 11
    Ko3S - 01+
    COMPRESSOR WHEEL
    Inducer: 38mm
    Exducer: 51mm
    Tip height: 4.4mm
    TURBINE WHEEL
    Inducer: 45mm
    Exducer: 38mm
    Tip height: 6.8mm
    Blades: 11
    Ko4-015
    COMPRESSOR WHEEL
    Inducer: 35mm
    Exducer: 50mm
    Tip height: 3.7mm
    TURBINE WHEEL
    Inducer: 50mm
    Exducer: 42mm
    Tip height: 6.4mm
    Blades: 11
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Mar 24 2013
    Oakdale, CT
    The S3 K04 (the one we want) is a K04-064 IIRC.
    -Adam
    Jul 09 2009
    Cleveland OH Area
    oh yeah, my bad. Stolen from another post on VW vortex
    From franken turbo
    The K04-064 has a modern-specification "full back" turbine rotor. What that means is the backplate in the casting carries all the way out to the rotor's widest edges. Dimensionally, it is a 50mm inducer and 44.5mm exducer.
    For more information on BorgWarner's state-of-the art turbo technology, I recommend this technical brief they offer. Turn to pages 13-15 for turbine rotor documentation.
    Kind of conflicting
    I have found Arin@APR said " When I measured the S3 k04 compressor wheel the inducer was 46.32mm and exducer 59.57mm." But I cannot find any information on the turbine. Trying to compare internal specs between a "normal" K04 and the Frankenturbo F23
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    If we send out our k03 for a rebuild and they can upgrade it to a k04, you need to specify you want the s3 k04 wheel? Or just let them do their job kinda thing?
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Aug 09 2007
    Mount Airy, MD
    Quote Originally Posted by Der Konig View Post
    Ko3 - 97-2000
    COMPRESSOR WHEEL
    Inducer: 33.6mm
    Exducer: 46mm
    Tip height: 3.7mm
    TURBINE WHEEL
    Inducer: 45mm
    Exducer: 38mm
    Tip height: 6.8mm
    Blades: 11
    Ko3S - 01+
    COMPRESSOR WHEEL
    Inducer: 38mm
    Exducer: 51mm
    Tip height: 4.4mm
    TURBINE WHEEL
    Inducer: 45mm
    Exducer: 38mm
    Tip height: 6.8mm
    Blades: 11
    Ko4-015
    COMPRESSOR WHEEL
    Inducer: 35mm
    Exducer: 50mm
    Tip height: 3.7mm
    TURBINE WHEEL
    Inducer: 50mm
    Exducer: 42mm
    Tip height: 6.4mm
    Blades: 11
    this is great info for b5's, not applicable for the b7
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by jerseybrian View Post
    Call and talk to them. If they don't know which one to use, they don't get your money.
    -Adam
    Jul 09 2009
    Cleveland OH Area
    Quote Originally Posted by SykoraA4 View Post
    Yeah my b, I believe we use the ko3s though, no? And I updated with info about the ko4-064
    Sent from my SM-N900V using Tapatalk
    Junior Member Two Rings
    Nov 19 2020
    Wyoming, USA
    Where did you send the K03 in to get it rebuilt?
    Is it more cost effective thank buying a new turbo?
    2004 Audi A4 B6 1.8T Quattro 6 speed MT
    Using OBDeleven atm
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    Quote Originally Posted by hawk06glide View Post
    It depends on few things
    1) Are you cheap and ok with it running few thousand miles and not worry about it too much- get a cheap chinese turbo on amazon
    2)Do you want to keep your car for long time but want to keep the replacement cost low- buy a known brand turbo like Mahle. you can get away with 500$ including tax
    3)if you are willing to spend money- buy genuine Borg warner for 1100$ including tax
    4) If your existing turbo has too many miles over 80-120k its not worth rebuilding and it will get costlier. 300$-400$(1-2 year warranty) if chra and wastegate needs to be replaced.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Well, Mahle are good turbos, but they are more like $750-$800. Ya can get an OEM BW for around $900 if ya shop around, $1100 with a full install kit.
    Sent from my LM-G710VM using Audizine Forum mobile app
