Results 1 to 7 of 7
    Aug 19 2013
    minnesota
    Front and rear strut and shock tighten loaded?
    Same question as my other post, do the lower bushings on the front struts and the rear shocks need to be tightened in a loaded position?
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    All suspension bushings should be tightened at normal (loaded) ride height.
    Aug 19 2013
    minnesota
    Thanks OG
    Aug 19 2013
    minnesota
    Even the sway links?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by jacobsen View Post
    Sway bar links are not loaded.
    Aug 19 2013
    minnesota
    Can I do one wheel at a time or should I get all for a loaded and then tighten them all at the same time? I'm noticing that resting the rear driver knuckle on a jack stand gives me a certain hieght but I can keep jacking it up higher.
    Dec 28 2006
    Western Maryland
    Think of it this way. Any bushing that gets locked into position once tightened should always be tightened with the vehicle in its normal riding position. Any bushing that can still rotate freely after tightened can be installed loaded or not. For example the sway bar bushings and rear sway bar links. The front sway bar end link bushings get locked so they should be tightened in the normal or "loaded" position.
    Yes you can tighten one corner at a time as long as that corner is in the normal loaded position. This is easy to accomplish by simply jacking up the knuckle to the point where the body of the car starts to move with the knuckle. At that point the suspension is carrying the full load of the vehicle. Another method is to simply pull the vehicle up on ramps and then do the final tightening of the bushings.
