    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    jacked up engine too high.. >:(
    was doing the motor mounts the other day and.. yup, went a little too high up. heard a crack and a few minutes later some pinkish fluid is dripping from the back of the engine.
    so coolant flange for sure, what else do you think i messed up?
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    I did that, but it ended up being the heater core return fitting that meets a coolant hard pipe on the back of the motor.
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Probably just cracked coolant flange. And while you're at it go ahead and put in a new coolant temperature sensor.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Man sorry to hear. Nothing worse than trying to fix problem and creating another
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jan 25 2011
    Philly
    thanks old guy. ill do that and move on worse scenarios if it doesnt fix it.
