Hi guys, I hope you can help me out here. I have just re installed my refreshed 058 stroker into my A4 and after approx 2k miles the turbo let go. The turbo company stated it was an oil pressure issue. I have an oil pressure gauge fitted and see 60 psi at 3k revs HOT and 20 psi HOT idle, with he feed for that taken from the oil pressure switch port.
Curiosity got the better of me so I hooked up a gauge into the oil feed line and found it to be be less . Using a -4an feed i was looking at 50 PSI at the housing end of the line and a tad over 40 on the turbo end. The feed is a decent size and never been an issue. I run a journal bearing K04-064 from a TFSI car on an adapterplate .
The engine in various formats has always produced about the same oil pressure, but i have never checked the turbo feed. I checked the housing for blockages and iot was all clear, but i note that the feed for the turbo is taken from outside the filter, whereas the switch / sender t is from the outside of the filter.
I don't want to fit the new core without being sure it's ok, but I have nothing to compare to.
Can anyone offer any insight please ??
