Results 1 to 17 of 17
    Jan 13 2014
    nyc
    Need advice from forum regarding engine noise. Thanks in advance
    Hey guys, i recently had my tranny rebuilt and a new stock turbo put in. Roughly 8k in repairs on my b8 a4. I brought her home and shes running fine but i have a weird rattle which is a combo of noise and vibration.....are any of you guys familiar with this?
    https://youtu.be/qVdPAZu5Cnk
    https://youtu.be/51MNT7HJZtE
    Thanks in advance for all of your wisdom.
    Aug 06 2012
    Parker, CO
    Did they pull the engine? Did they replace the engine and TRANS mounts with new hardware?
    Also --- no more vertical video. Please turn your phone 90-degrees and give the world more to see.
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    sounds normal to me
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Jan 13 2014
    nyc
    Hey sorry guys.... no more vertical videos
    Engine was rebuilt by audi last year. Valve body and a couple of other parts were replaced along with a new turbo with that small metal clip which goes on the wastegate arm.
    All parts installed were new oem parts. I had put in the 034 motorsorts tranny mount a while back.
    So you guys think it aounds normal?
    What about the shaking?
    Active Member One Ring Prorider's Avatar
    May 23 2015
    La Antigua Guatemala
    Mine started rattling some months ago... like noisier than normal. Took him to the dealership and they found that a nut of the steering wheel was loose... retightened it and back to normal. Check that
    2009 Audi A4 B8, 1.8TFSI (118kw), FWD, 6-speed manual, deep sea blue pearl, mustang maroon leather seats, dark brown walnut wood inserts.
    Established Member Two Rings 2k12A4's Avatar
    Feb 26 2016
    83 c10
    Los Angeles, CA
    Mine has the same little "knocking" type of sound. I'm also curious to see if it's normal
    Jan 13 2014
    nyc
    Can you post a video to youtube and provide link?
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    Good Lord dude 8k? Thats eccessive for those repairs.
    Jan 13 2014
    nyc
    Really? The parts alone were close to 6k
    Torque converter and its seal
    Mechatron and atf oil
    New turbo plus all gaskets and clip
    Oil and filter
    Crank position sensor
    Diagnostic and install
    Plus some minor stuff i bought....
    Ecs street shield and oil dipstick
    R8 coil packs i havent installed yet...
    I think thats it. I honestly dont feel i wasted my money. Just want forum member input on the vibration and sewing machine sound.
    Thanks everyone!
    Jan 13 2014
    nyc
    Quote Originally Posted by ILVTRANCE View Post
    sounds normal to me
    Hey man yours sounds the same?
    What part of ny are u in?
    Dec 19 2012
    New York
    i'm in rockland county. Ill take a better listen to your video.
    Dec 19 2012
    New York
    ill try to get a video together
    Jan 13 2014
    nyc
    Thanks bro im from long island....i would have met up just to hear your vehicle idle.
    Dec 01 2011
    i had a similar noise but it was louder and had a sort of helicopter type rhythm to it. ended up being a bad tensioner and i had it like that for 1-2 months until it got worse and started screeching and smoking from grinding the belt at one point. also the alternator itself had a bad pulley/bearing or something where the belt attached, not sure which happened first and caused the others to go bad maybe, but i had to pretty much get alternator, belt, and tensioner replaced.
    IG @theshawon
    Established Member Two Rings TVP125's Avatar
    Dec 14 2015
    Palm Beach, FL
    Quote Originally Posted by 2k12A4 View Post
    Mine is also making a similar sound. I took the video below last night. The sound I'm referring to is coming from the upper timing chain cover not the direct injection noise.
    12 Audi A4 S-Line
    EURODYNE FrankenTurbo F23L
    K&N Typhoon Intake
    Magnaflow Sport Series 3" Turbo Back Exhaust
    Treadstone TR8L Intercooler
    ST Coilovers
    Jan 13 2014
    nyc
    Quote Originally Posted by TVP125 View Post
    Basically same noise mine makes but with a vibration to it. Had the engine mounts replaced with the 034 mounts. Bought the tranny mount rebuilt tranny bought a new turbo...at this point im about to drop another 2 grand to try and remedy it. But seriously fuck audi at thia point. I might switch to Infiniti x series or lexus f awd
    Jan 13 2014
    nyc
    Honestly all the work im doing to this shit and its one thing after the other. Thats nearly 10k already Its like these cars are not meant to be kept, only leased and returned cause they dont last long. Dont get me wrong ive been an audi fan all of my life.....but shit, i hvae gotten discounts on the parts and the repairs by certified prosche and audi mechs and im still not near 90 percent. Definitely leaning towards lexus f the more i think about it and fuck this audi love of mine. Had a misdiagnosis by audi of lynbrook when my wastegate failed and would have gotten a new turbo but ended up paying for it out of my own pocket because of their incompetent technicians. Called aoa and they politely told me im shit out of luck.......ive spoiled and babied this german bitch but she hasnt loved me back and im about to dip and start a new relationship with a jap
