Hello all,
My A6 recently developed a pretty noticeable vibration inside the car, and I've determined that it is the motor mounts that need to be replaced. I have already ordered both of them and they should be here next week. I am having trouble finding any sort of guide for our cars that would help me with my little adventure. I found this on another Audi forum, which does help, but is by no means a comprehensive how-to.
"Indeed I did! I replaced the front right mount it was very easy and straight forward you do need the triple square spline driver set (14mm) you need to order these most auto places will have up to 10mm-12mm but NO ONE had 14mm so I ordered the complete set on amazon. You need to take the front pass. side tire off along with the plastic cover/shroud above the tire, my apologies for not taking pics but there are 2 10mm bolts holding a "nut bracket" attached to the engine mount under car take those out unplug the mount(has a solenoid to restrict flow)((oil filled motor mount)) then take out 3 triple square, 2-12mm and top one is 14mm from the tire side, I have a lift so I put a floor jack with a long 4"x4" under engine to take off the weight from the mount. Remove the nut bracket and grab a big pry bar to work the mount out....not much just needs some "talkin too"! Install new mount in reverse order "
Just wondering if anyone has any pictures/instructions that would help me replace my old left and right mounts. I will be taking off the bumper at the same time to swap the grille, so that should give me a little extra room to work. Any help appreciated!
Thanks,
Zack
