    Senior Member Three Rings pule333's Avatar
    Jan 14 2013
    Mi4cxl
    london/UK
    Rs4 b7 lambda sensor B2S1 connector location
    Hi guys. As above, where does it connect to??? Searched and searched but no luck finding any kind of how to or DIY or even a picture of where those plugs are located... Really don't wanna take car to garage for this, should be an easy enough job if I can locate the plug port that is. Any info on this would be highly appreciated...
    Below is a little picture to spice this up ;)
    Vorsprung durch Technik
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    on top of the transmission. all 4 are there.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Jan 14 2013
    Mi4cxl
    london/UK
    Quote Originally Posted by your daddy View Post
    no freaking way
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Right hand side, above the Trans. carrier.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Jan 14 2013
    Mi4cxl
    london/UK
    Quote Originally Posted by ven0m View Post
    Thank you for confirming!!!!!
