Results 1 to 18 of 18
Thread: A/C Fan Issue
    Jun 07 2014
    United States
    A/C Fan Issue
    Having A/C issues, of course in the middle of summer. I can't pin down the cause. A/C blows cold while driving but not at a stand still and freon pressure is fine. When I turn the A/C on, the cooling fans start to spin (not really fast) and then stop, then start, then stop. I can hear the compressor engaging but then disengaging when the fans stop. Is this a faulty fan? or control module?
    Saltine
    Veteran Member Three Rings idrinkv8's Avatar
    Nov 01 2008
    Bump for a reply on this. Having a similar issue, was gonna change my coolant temp sensor for $30 first and see what happens. Common sensor failure so... Next would be to hook up the VAG and test the fans. Possibly fan control module.
    Through my research I've narrowed it down to a few things:
    Fan control module
    Fan relay
    Coolant temp sensor
    Any other possibilities?
    Jun 07 2014
    United States
    Thanks. Another reason I'm leaning towards fans is they used to turn on full speed as soon as the car was started when the ac was on. So I'm thinking low speed was already dead and now high speed bit the dust?
    2008
    113,000 miles
    Nov 01 2008
    I know I'm leaning towards the same thing... hope it's not the fan control module...
    Nov 01 2008
    Found this to test the fans http://forums.vwvortex.com/showthrea...4448717?page=1
    Jun 07 2014
    United States
    My issue is the pictures aren't loading and I'm not sure which connector to put voltage to. I jacked up the car and found one electrical connector but it was only two pronged so I wasn't sure it was the fan motors power cable and didn't want to blow anything putting voltage to the wrongs connector.
    Nov 01 2008
    Yeah the plug they're talking about isn't under the car. Pretty sure it the one coming directly from the fan control module.
    Nov 01 2008
    Nov 01 2008
    Jun 07 2014
    United States
    Thanks! I'll try this when I get back in town. still would be nice to get a pic of where that connector is located. I looked a couple times but I haven't been under the hood of this car much, been running pretty good for me the past 4 years.
    Jun 07 2014
    United States
    Looks like I'm also overdue for a Timing Belt swap, guess it's time to sharpen my mechanic skills....
    Nov 01 2008
    Yikes, good luck with that.
    Nov 01 2008
    Jump the orange for one fan and the yellow for the other fan.
    Jun 07 2014
    United States
    Just a heads up, ended up swapping out the entire fan unit, it's all working now! Also did the timing belt kit, thermostat, so far so good!
    Thanks,
    salt
    Nov 01 2008
    So, bad fans then I suppose
    Nov 01 2008
    Quote Originally Posted by saltine View Post
    Thanks,
    salt
    When you did the fans did you swap out the shroud too or just the individual fans?
    Jun 07 2014
    United States
    Quote Originally Posted by idrinkv8 View Post
    Ordered this. TYC 622540 Replacement Cooling Fan Assembly for Audi A4 https://www.amazon.com/dp/B00BG3GPYK..._iTYSxbMYBKEDF
    The mechanic had to remove the old fans from the assembly and attach this. It was 4 bolts if I remember correctly.
    Nov 01 2008
    Gotcha makes sense
