Originally Posted by
BG SQ5
Sounds kinda like the classic 'B pillar rattle'. I would describe mine more like i high frequency plastic buzz. Some say it's the rear door exterior glossy black trim piece (applique) where it contacts the inside of the door. Others find i emanating from seatbelt area. Google 'Q5 B pillar rattle' and you'll get a bunch of info. I haven't tracked mine down yet, but I think it's the applique.
Thanks for the info. With your recommendation, I searched through some of threads and although I do not have any rattling so to speak, it is possible the random, single clicking sound is coming from inside the seat belt assembly area inside the pillar. At least it helps me localize "the click" if I can not track it down inside the cabin. I also read that someone found that the seat belt harness under the rear passenger seat was the culprit, so if/when I have a tech ride around with me, I can keep that in mind for them as well.
Probmxstyle
My rear cargo cover was making a similar noise. Take it out and see if the noise goes away.
ThunderDent
Seconded.
I have had mine out of both my Q's due to this, plus it gives you lots more room.
Easy enough. Will try this and report back. Thanks.
S-Fore
Check that it is not your seat belt buckle flopping around hitting the plastic moulding. Mine does it on my pass front, its annoying...
Based on the type of sound and location, this is what I thought it was originally but I ruled it out.
I really appreciate the input. The click is interfering with my enjoyment of the vehicle and IT MUST GO!
