Results 1 to 7 of 7
    Active Member Two Rings Boost92's Avatar
    Dec 11 2015
    Norway
    Podi Audi B6 A4 Stepper Motor Boost/Oil Pressure Dual Gauge wireing help
    Do someone have a diagram for where to tap in with the wires?
    Thanks
    Aug 26 2005
    The brand and model number of the gauge you have is required to be able to help.
    Vorsprung durch Technik
    Dec 11 2015
    Norway
    Its Podi Stepper motor boost gauge kit.
    http://www.podi.ca/audi-b6-b7-a4-s4-...gauge-package/
    Apr 15 2014
    Ottawa/Gatineau Canada
    just find a 12V switched and a 12v constant in the fuse box and tap into those with the provided fuse taps.
    I am on my way out the door, but when I get back tonight I can take a look in my fuse box and tell you what fuses I tapped, if you have not figured it out by then.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 11 2015
    Norway
    Quote Originally Posted by Luxus Panzer View Post
    That would be great :)
    Thanks
    Apr 15 2014
    here are my hook ups for my Podi
    Looks like I wrote myself a note in here for future reference...worked out well ;) It says....
    #39 = Radio. 12V constant. stays live during engine start.
    #5 = 12v switched. Stays live during engine start.
    You should be good to go now.
    Dec 11 2015
    Norway
    Nice :D Thanks man ;D
