Page 1 of 3 123 LastLast
Results 1 to 40 of 92
    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    01 A4 1.8T GT2871R build
    This is gonna be a longterm thread with bunch of pics of progress along the way
    Im planning on getting a gt2871r and putting forged rods into the engine but i might change my mind along the way.
    For now ill start with the car which is 01 1.8t awm briliant black i think....
    I picked it up for $700 with 210k on the clock
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Great deal.
    Do not go with a Gt2871r, that's old world, if a Gt2871r was a phone it would be a BlackBerry. Sure, it's works but that's old school, you wouldn't use a Pentium 4 chip for todays computer. A same size modern turbo will produce more power, sooner, hold it longer and have a broader usable powerband. Talk to Mike Hood @ Ringer Racing.
    May 17 2014
    Raleigh, NC
    get a gtx over teh 2871... or even get a billet up grade at least for it.
    If i were spending my $ again on a set up it would be EFR or bust.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by A1 A2 German View Post
    The unicorn!
    Most wanted turbo in history.
    ftfy
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Feb 28 2005
    Tempe
    Quote Originally Posted by GrapeBandit View Post
    ftfy
    Lol, Gt2871r vs Gt2871r Elim, built motor full frame vs stock motor stock location, where there is no other KKK elim choice so it's that elim by default as there are no modern turbos which exceed it.
    Dec 13 2010
    FL
    lol my bad. didnt realize OP's gt2871 is full frame
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    Quote Originally Posted by rodgertherabit View Post
    After learning about EFR's that's the way I'll go once my motor is built. Once and done...
    Sent from my VS990 using Tapatalk
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Sep 12 2008
    South Central PA
    EFR for life
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Feb 28 2005
    Tempe
    There's a complete irony with my statement though.
    With "my wants" or what I'm stating is if they made a modern, more efficient, "today's version/today's tech" gt2871r elim.....we ~couldn't use it. The irony of having a better Elim is the stock motor would window the block, as it stands many believe a gt2871r elim is already pushing it and would consider rods. Granted if you added rods......you wouldn't run a small frame (as most would want to go full frame).
    Dec 29 2015
    B5 S4
    Illinois
    Right now the car is not moving by its own so first im going to figure out whats wrong with it, the previous owner said it is the clutch for sure but im not so sure since when you engage the clutch in gear the mph gose up and you can hear metalic grinding noise
    Gonna drop the trans, check out the clutch and peak inside the trans
    If all looks like its the clutch i will probably order stage 2 southbend clutch
    Dec 29 2015
    B5 S4
    Illinois
    The car has been sitting for a while so i decided to do a coolant flush this is what came out
    This is after 3 flushes with distilled water
    I flushed it 5 times with water and put in the g13 mixed coolant for now, i ordered a refresh kit for the cooling system aswell
    Im gonna flush it two more times at least
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Before you flush more, take the reservoir off and flush that by hand. You want to get water in it and shake it around to get any deposits out. The reservoir acts as a trap for particulate matter.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Dec 29 2015
    B5 S4
    Illinois
    I picked up this kit and it should do the job
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by CoyneJ View Post
    I purchased this kit. If your coolant temp sensor isn't failed I wouksnt put the one from this kit in. It is a URO coolant temp sensor and mine failed in ~16k miles. Just a heads up.
    Sent from my LG-H815 using Tapatalk
    Aug 23 2014
    Tucson
    Another warning would be to keep an eye on your coolant level as the aftermarket resevoirs can be hit or miss. Mine lasted a month before springing a very small leak.
    Dec 29 2015
    B5 S4
    Illinois
    Anyone know why would all the windows and locks not work?
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    Centra locking pump failure.
    Dec 29 2015
    B5 S4
    Illinois
    Got the new sensor in but riped the pcv lol
    Oct 24 2011
    New Jersey
    I'd say that was on borrowed time haha
    Dec 29 2015
    B5 S4
    Illinois
    Lol other parts dont look to well either
    Cv shaft completly snaped
    Rear righr spring snaped aswell which explains why the car was low
    Brakes look great tho 😁
    Sep 12 2008
    South Central PA
    that CV is completely fucked. did you actually drive it on that?
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Dec 29 2015
    B5 S4
    Illinois
    Bought it like that lol
    Dec 29 2015
    B5 S4
    Illinois
    Was wondering where it fell lol
    Dec 29 2015
    B5 S4
    Illinois
    What's the safest way to open transmission without messing something up to look inside and dose the clutch look blown I never did this before
    Dec 29 2015
    B5 S4
    Illinois
    I was told the car won't move because of the broken axle and the clutch still has some life on it
    Feb 06 2013
    WV
    I am late to the party, I was going to tell you it was the broken axle. I had the exact same thing happen to me and had the engine out before I figured the issue was the damn cv. Yay.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    That coolant flush though! WTF! O.O
    2016 S3
    Instagram- @Thisisastickup
    Dec 29 2015
    B5 S4
    Illinois
    im probably gonna put this car back together for now and get it running so i can buy all the parts i need for the build and do the timing belt on my 2.8 a4
    parts to buy:
    Clutch: Southbend Stage 2
    Suspension: bilstein sport with race H&R springs
    Turbo: undecided yet need to do more research
    Engine and trans mounts
    Timing Belt
    Forged rods
    Head gaskets and all seals
    Front cv axles...
    cx racing exhaust
    brakes
    Nov 03 2014
    Missouri, US
    Unless you have a serious hard on for the B5, you might consider other alternatives. I started about where you're at and I'm already around $14,000 into the project with none of the "cool stuff" like suspension and aftermarket body stuff etc. did all the work myself even. You can get a pretty damn nice car for that kind of money down, hell, that's down payment for a house money lol
    Edit: Take what I said with a grain of salt, I'm actually a bit OCD maybe and what I actually ended up doing is a near match to this thread
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by kruftindustries View Post
    That's on you then. No way I buy 14k without cool stuff if ur diying.
    Nov 03 2014
    Missouri, US
    To give some sort of reference, I think it was around $400 to replace all the hoses and vacuum lines with silicone. Balance and blueprint, block work was around $900 and valve job was $250. Supertech makes sodium filled inconel valves, (I'll be making a thread if I drop one).. Cracked driver seat lower replacement was $450 from stealership.. Again grain of salt, I did a tad more than get it running, and I have a lot more to go before it's "done"
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Nice pickup looks like you have some work ahead of you, have fun. as others said unless you get a super deal go with a newer turbo setup. few more $$$ but in the end you'll be glad you did.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Dec 05 2007
    With an open differential the car won't move if even one cv joint is compromised. That was your issue of why car would not move, not clutch.
    Dec 29 2015
    B5 S4
    Illinois
    Quote Originally Posted by GOODBYNAAIR View Post
    What's a good turbo for ~400hp
    Oct 24 2011
    New Jersey
    Hey that's my threas! Haha.
    I'm definitely not that deep into it. I also had a parts car though which helped a little bit. I don't know exactly how much I'm in but it's somewhere between 6 and 7k.
    Senior Member Two Rings genecan's Avatar
    Apr 29 2007
    Bulgaria
    Quote Originally Posted by 'Dan[FN
    EFR for life
    x2
    1999.5 A4 B5 1.8TQ (ANB) -> 2.0L AEB EFR 7163 - http://www.audizine.com/forum/showth...ight=evolution
    Nov 17 2011
    Fredneck Maryland
    400whp? GTX30 would do that and many of the EFR, Comp, precision, turbos would make that to. but supporting mods are needed with any turbo looking to make that number. Really you need to think about more that just the number of 400hp thinks like spool and what you want to do with the car drag , autox, DD ect
    Dec 29 2015
    B5 S4
    Illinois
    Just got my axels and got the flywheel out
    Planning on getting the flywheel machined tomorrow
    Also I just ordered
    Test pipe
    Cxracing exhaust
    Stage 2 southbent clutch
    Stage 2 eurodyne ecu
    I'm probably gonna try to get the car running on Monday if all gose well
    Dec 29 2015
    B5 S4
    Illinois
    Picked up a central locking pump from a junk yard for 10$ and all the windows and locks work now
    There were also oem hids headlights for 50 not sure if I should go back and get them
    Sep 12 2008
    South Central PA
    very cool! $50 is decent if they're in good shape
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
