Results 1 to 8 of 8
    Established Member Two Rings Wyd's Avatar
    Jun 29 2016
    WA
    oil pump, oil pressure
    I recently did my much needed oil check valve service and new valve cover gaskets.
    after a lot of scrubbing and 16 hour days, i still have an oil pressure light
    i had the oil completely drained and noticed when pulling the valley pan that oil was filled up and puddles where the oil spray valve and upper(farthest back) oil check valve sit.
    im not entirely how or where the pump and pickup manifold sit underneath. would be nice if someone could provide/link a diy for the oil pump job so i could take a look
    parts replaced:
    oil check valves
    oil spray valve
    crankcase vent valve
    crankcase seal
    valley pan gasket
    All three filters except >(not sure what the small triangular filter at the back up the front intake part is called)
    valve cover gaskets
    spark plugs
    oil pressure switch
    Also if someone could chime in on my red cooling system light(sorry to pack it all into one post)
    car seems to run fairly hot but the temp/vag401 reads normal temp
    ie. everything under the hood is hot, EVERYTHING. resivor is really hot even
    -coolant is filled all the way
    Aug 09 2012
    Bay Area
    Quote Originally Posted by Wyd View Post
    parts replaced:
    oil check valves
    oil spray valve
    crankcase seal
    valley pan gasket
    valve cover gaskets
    spark plugs
    Check your oil pressure switch. Its on the back of the oil filter housing. I don't see it in your list so i'm assuming it hasn't been inspected yet.
    http://www.audizine.com/forum/showth...D-oil-light-on
    Jun 29 2016
    WA
    Quote Originally Posted by Kambesama View Post
    Forgot to add that to the list. first thing i replaced
    Aug 09 2012
    Bay Area
    Ah if that's the case I'd recommend seeing if you can put a gauge to measure actual oil pressure and double check the connector to make sure the pin is nice and tight.
    Jun 29 2016
    WA
    any advice on how to go about it? The last time i couldn't get a proper seal as there hardly any space, Gave up after 2 hours of frustrating 1/4 turns of a wrench
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    What weight oil are you using?
    Jun 29 2016
    WA
    Quote Originally Posted by kevinye77137 View Post
    0/40, switching back to 5/40
    Jul 13 2014
    1997BMWZ3
    Try 10w40 or 15w50
