Results 1 to 15 of 15
    Feb 01 2016
    09 A6 3.0T (Sold), 11 Cooper ALL4 S, 2013 S5
    Lowell, MA
    MMI reverse camera
    So, I've been looking at ads for S6 and S8, none of which will do my economic health any good at all, I'll try to resist.
    One thing I did notice though, earlier models with the same MMI as my 2009 A6 seem to come equipped with rear reversing camera.
    How complicated is it to add this to the A6?
    2013 S5, B&O, Sports Diff, Nav Plus, Carbon inlays, Akebono, APR Stage 2, Dual Pulley, DSG Tune, APR intake and back pipe. KW HAS. Variant 20x10, Carbon Imports rear spoiler, RS Grill, Passport 9500i and night surveillance by Blackvue :) Ultracharger and Intercooler, ECS X-pipe
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    A search shows this up pretty good.
    You need the oem equipment, module, wiring, camera, some other stuff and then the ability to code it using software.
    Last time I looked into it I was better off buying a wrecked a6 with the rearview camera and taking what I need then parting the rest of the car out. lol
    I think it was over a grand.
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Jul 17 2011
    Sin City, USA
    I have done extensive research into this myself and, unfortunately, there is no aftermarket system for the MMI. Therefore, as @JPJ2007 stated, you would need to source all the OEM componenets for install.
    '09 C6.5 A6
    Feb 01 2016
    Lowell, MA
    Thanks JP and SIN and I apologise for not having used the search function, I tend to overlook that on my phone.
    I certainly like the idea of having the rear camera but I think in terms of bang for buck it's probably a non starter.
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    I looked into doing this a while back through a custom electronics shop in the city, would have been done well and had multi angle camera that i could shift using a button inside that would be mounted separately but it would have cost between 1300-1800 depending on the camera i selected.
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Apr 15 2009
    Middle TN
    Yeah thats crazy. I really miss having the RearView Camera like my wife has but i'm not paying thousands for it. If I bought a car or the parts and then could recupe my costs by parting the rest of the vehicle out sure, but really I'm going to probably buy a newer audi next year and i'll just make sure it has the camera.
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Another option, a bit pricey when it is available:
    http://www.macrumors.com/2016/06/21/...es-rearvision/
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Sep 07 2015
    Ann Arbor, MI USA
    I added the Audi rear view camera to my 2010 A6, here's my write up:
    http://www.audizine.com/forum/showth...ar-View-Camera
    Well worth it, having a backup camera. I have young kids so I really appreciate it. The install was moderate in difficulty, the hardest part was figuring out what I needed to buy and making sure it would work.
    Feb 01 2016
    Lowell, MA
    That's a really useful write up, thank you!!!!
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    I've done some digging and found a video that seems promising. Also linked the company page
    https://www.youtube.com/watch?v=ohzcenDJbjs
    http://www.carsgadget.com/
    Edit:
    I should add, the video is of a b8.5..... but maybe this will work with alll 3G applications
    Senior Member Three Rings dluxxx's Avatar
    Mar 13 2013
    2016 Porsche Cayenne Diesel
    Nor*Cal
    Quote Originally Posted by 2010A6 View Post
    Edit:
    If you look here: http://www.carsgadget.com/product-pa...3-03b67bbe20a9
    it says it works for 2010-2015 A6 w/ 3G MMI. So it should work. Who will be the guinea pig? lol
    2010 A6 C6.5 3.0T, Remus Mufflers w/ Quad tips, Magnaflow Resonated X-Pipe, RocEuro Intake, EPL Stage 1, Transparent Gloss Copper Verde Axis V99 20x9, Michelin Pilot Sport 4S 265/30, Bilstein P14 PSS Coilover, H&R Rear Sway Bar, Ultra Racing Front Lower Brace, Ultra Racing Center Lower Brace, RS6 Black Gloss Grill, Rear diffuser, Black Vinyl window trim, Smoked Rear Tailights, Complete Interior LED Lights, Blacked out front sidemarkers, Morimoto 5000k D3S bulbs, SB3 Alpha Ceramic Coating.
    Mar 10 2015
    Albany, NY
    Quote Originally Posted by dluxxx View Post
    I will be come spring if anyone hasn't done it prior.
    All mod progress has stopped until after the snow leaves
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Established Member Two Rings mrismail's Avatar
    Oct 27 2014
    Las Vegas, NV
    Edit:
    I just finished installing this. I ran into 3 problems. I have original rear sensors installed, they sent me a harness that is supposed to plug into the rear sensor module in the trunk and from there plug into the module. The pins on this harness did not seem to line up with the original canbus beige plug that goes into the sensor module. I modified the cable and tapped the canbus cables from behind the climate control unit. Another problem I ran into was the guidelines did not move when the steering wheel was turned. Also, I purchased the front camera to hook up, but, it didnt switch to it when I placed the car into drive. Seller said, it should switch for 10 seconds then return to MMI screen. It got cold and I ran out of daylight but I plan on resetting MMI and messing with Vagcom to see if I can change any settings to make it work. Aside from that, rear camera works when placed in reverse and rear sensors still work with lil car and sensors present on screen.
    BTW, I have a MMI 3G+ (w/ HD) and original rear parking sensors.
    UPDATE:
    1 more problem. the camera, trunk lid handle might not match the housing you have in your car. I'm pretty sure they're designed for the C7 based on hole placements for screws. I was able to modify mine to fit. I had to apply some hot glue on the metal clicker in the housing so that the handle can reach it when pushed from the outside. seems like it's about 4 mm short. I wish I took pictures to do a complete DIY but it was freezing and snowing when I was installing this on the streets of Brooklyn.
    I still havent been able to figure out how to get the guidelines activated. Aside from that, I have a backup camera when shifted into R.
    UPDATE 2:
    This video helped me a bit when I was modifying my harness. Not sure if the kit was purchased from carsgadget.com or not but the module looks similar to mine.
    https://www.youtube.com/watch?v=BrBzTMEt3cY
    UPDATE 3:
    So, Once the TPMS light went off after driving about 10 miles... the guidelines now work. The front camera does not engage for 10 seconds when placed in D as advertised by company.
    Overall, impression... Camera is great quality, guidelines function. Install, is not difficult but may vary and require some slight modification to handle. There are several locations to access canbus, easiest for me was from plug in climatronic control.
    There are several of these systems floating around ebay at half the cost. Not sure you'll get any costumer support or if the trunk handle has been tested and fits properly.
    2011 3.2L S-Line Premium Plus
    Current mods:
    ST Coilovers | G6 3000K LED Fog Lights | Blacked out with PlastiDip: Chrome trim, front grill, rear emblem, corner lights | Quad tips | 25% 3M tint all around | 4000K LED license plate | 20x10 Rear and 20x9 Front Wheels| Black vinyl wrapped roof | Rear trunk spoiler | Rear window spoiler | Tinted rear lights | SLine steering wheel with paddle shifters |
    Feb 01 2016
    Lowell, MA
    Quote Originally Posted by mrismail View Post
    UPDATE:
    UPDATE 2:
    UPDATE 3:
    Thank you for this very comprehensive feedback, it is much appreciated.!!
    Sep 25 2012
    Los Angeles, CA
    Hey I was just wondering if anyone else has tried this reverse camera? Anyone getting it to work with no issues?
    Thanks,
    Robert
