    Senior Member Two Rings MrSnickelsnizer's Avatar
    Dec 03 2012
    michigan
    Power Loss at 5,000rpm + under acceleration
    Title states it all. I am pretty sure it is a boost leak somewhere. Will boost leak test tomorrow. Or maybe throttle body adaption...
    But the question is does a boost leak sound plausible? Car falls on its face at high boost. No low boost issues.
    3rd gear, 5,200 rpm car just jerks and stops accelerating. Not a clutch issue. Clutch is brand spankin new.
    Car is Giac Stage 1 chipped.
    No engine codes, or anything.
    This is a recent issue. Never experienced an issue like this in all the years and miles of ownership of this car. So I guess i am a little concerned due to that.
    1998 Audi A4 1.8t Quattro
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Do you have a cat installed? Sounds to me like it is an exhaust restriction. Does acceleration feel impacted at all?
    Sent from my LG-H815 using Tapatalk
    Dec 03 2012
    michigan
    No exhaust issues. Cat was recently out and looked good. Acceleration is good until stated rpms.
    Mar 20 2009
    Scotland
    My old TQS did something similar. Initially it was gradual, just a flatness after 5k and a sort of missfirey feeling if you tried to rev it out. Logging showed nothing unusual bar a bit of timing pull. I did the usual plugs/coils/MAF etc. but it just seemed to get worse and worse over time, then very quickly deteriorated to the point where it couldnt make more than 5psi even with the actuator line completely disconnected fom the turbo, timing pull was off the scale and i was properly scratching my head.
    In the end i popped the lamdba probe out the exhaust, and boost went from 5psi up to about 8. The exhaust was so blocked that the lambda probe hole massively increased the available exhaust flow.
    Pulled the cat out and the monolith had disintegrated and was jamming the outlet. Another telltale that i missed was the inside of exhaust tailpipes had gone a sort of white color, rather than their usual sooty-black. Replaced the cat and boom, power returned.
    However, my track car is exhibiting similar symptoms, goes properly flat at 5k and feels like its lost about 100hp. Change gear and power returns instantly. It has a decat though, so its not a cat issue on that one. My current thoughts on that is that its the intercooler heatsoaking and ECU going into protection mode, so i've got a bigger cooler for it and will see how that goes.
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Throttle body adaptation would be a great idea.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
