Results 1 to 13 of 13
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Crank Pulley Replacement
    I have been doing some research on failing crank pulleys and Im curious as to what mileage people are changing them at. Im at 38k now, is this something I should be doing soon? Thoughts on best replacement?
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Mine went last weekend.. 41k.. New crank pulley and new belts.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jun 12 2015
    CA
    I replaced mine at 10k and again at 12k. My OEM crank pulley failed...to make the car go fast enough.
    Jul 04 2008
    York, PA
    Quote Originally Posted by DGVR6 View Post
    No other damage done?
    - - - Updated - - -
    Quote Originally Posted by colby7 View Post
    What did you go with?
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I'm curious as well. I'm also curious if or how much sooner they will fail with Stage 2.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by cjw View Post
    I'm wondering too. I want to go JHM crank pulley with stock pulley and be done with it. That should equal stage 2 right?
    2011 Deep Sea Blue S4
    7-speed DSG / B&O / MMI with Nav / Advanced Key / Carbon Atlas Inlays / Black Leather /19" Peelers/Push Button Start/Sport-Diff/Comfort Mode;)
    Modifications: Stage 2 GIAC w/Emmanuel Design Pulley, TCU DSG GIAC Tune, EuroCode Alu Kreuz, Roc Euro Intake, 034 Trans mount, Apikol mount, H&R front & rear sways
    Jun 12 2015
    CA
    Quote Originally Posted by 4Rings3Liters View Post
    - - - Updated - - -
    179 JHM, then 194 KI
    Aug 03 2014
    Queens
    Need to replace passenger fender liner and hood insulation. Other than that, good to go.
    Going with jhm pretty soon
    Previous
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Didn't they redesign it for the b8.5?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    What happens when it fails and how catastrophic is it? no damage just can't drive or potential internal engine damage?
    Aug 03 2014
    Queens
    You'll have no accessories, main one being water pump.. You'll overheat if you keep driving it.
    Heard of it taking out other things in the bay but I was lucky. So yea it can get pretty bad.
    Previous
    Jul 04 2008
    York, PA
    Quote Originally Posted by Hofahome View Post
    Is this true?
    Aug 11 2015
    Alberta
    I'm at 40 k with Stage 2 for just about 3 k of those on a 2013.
    I figured I had lots of time before I needed to worry about this as it really doesn't seem that common, and mostly on older, higher mileage cars.
