Hello! I'd like to start by saying I just recently purchased my first Audi, 2003 A4 1.8t. I have used audizine to reference and answer many questions I've had regarding the car. Now I have encountered issues that I do not know where to begin with. Help would be greatly appreciated.
Shortly after purchasing the vehicle I encountered problems with cel, esp, and epc light illuminating the dash. With these lights came loss of power (limited to 2000rpm) sporadic idle sometimes high around 2k, sometimes low,with the occasional stall out. Also the car would not start sometimes if warm,had to let cool to start. After a little research thought maybe the crank position sensor was at fault. Replaced the sensor hooked battery back up and the car ran normally again. Attempting to take it to work it died out on the highway while I was gassing her up a little more, again cel, esp, epc lights. Towed to dealership and they had a $3000 service invoice for problems with throttle body(said a new one was needed) possible crank sensor, rear axle seals leaking differential fluid, and some simple break recommendation and hoses. Assuming the quote was a little unreasonable I had the vehicle towed to an independant shop. Mechanic drove vehicle without problem for a week returning it to me insisting everything was fine, he pulled no Engine faults, and was surprised with power of little 1.8t. Was a little concerned but happy things were running as they should.
One week after picking it up, maybe 300 miles driven and I again the cel came on, and I notice a hesitation, slight Jerking from the front end at cruising speeds.
Other issues at hand: Windshield wipers will not park at home position, and will not stop unless the fuse is removed.
After disconecting negative battery terminal and putting it back on,symphony II radio has been unresponsive. Checked 20amp in fuse panel and 10amp in back of HU and both were ok. When reinstalling fuses I could hear disc changer but there is no display, does not play music.
Have always dreamed of owning an audi and had a list of mods in mind ( As soon as I can get it running normal) but this car is sucking the life out of me and my wallet. Sweet car, but came here looking for all the help I could get so hopefully in the future I won't be turned away from the audi brand. Sorry to be long winded,just so much going on its hard to say it all in a short sentence. Thanks in advance for the help!!
Owned vehicle 3 monthes driven vehicle maybe 1:(
