Results 1 to 17 of 17
    Aug 19 2013
    minnesota
    Caliper slide pin dust caps
    Anyone know where to get the caliper slide pin dust caps cheap? They're $55 for 8 of these things which would cover each caliper. Part number is 11819000671 or the kit is 8V0698647 which is cheaper on ebay. Sadly in my searching the dealership is the cheapest so far. Maybe junkyard is the way to go? I accidentally threw the old ones out. My S4 brakes don't have caps on the slide pins.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 26 2005
    Wrecking yard soft parts are a crap shoot. $55 to cover all four calipers does not seem expensive to me. The boots are a relativity critical part for reliable brakes.
    Vorsprung durch Technik
    Aug 19 2013
    minnesota
    I might go with the stiffening kit, it gets rave reviews.
    Aug 19 2013
    minnesota
    If I'm spending 50 some bucks might as well spend a little more and get the stiffening kit.
    Aug 19 2013
    minnesota
    My question is does the stiffening kit fit the B7 S4 brakes? Are there different kits for the A4 caliper and S4 caliper?
    Apr 07 2011
    Fits the following Audi models:
    1996-present Audi A4 1.8T/2.8L.
    1996-present Audi A6 2.8L.
    2000-2007 Audi TT (1.8T/ 225hp 1.8T)
    2003-2005 Audi B6 S4
    2006-present Audi A3 2.0T/3.2Q
    2010 Audi A3 TDI
    2008-present Audi TT 2.0T, 3.2, and TTS
    1998-2005 Audi A6 2.7T with 4 pad brake setup. (Not 8 pad brake setup).
    2005.5-2008 B7 Audi A4
    Aug 19 2013
    minnesota
    I know I speak too soon. I checked it out. Cool beans...
    Jun 27 2011
    Quote Originally Posted by jacobsen View Post
    Yes. Same kits for all b6s and b7s (minus the RS4).
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    I recently replaced my front brake bushings with this kit from O'Reilly Auto Parts. Comes with the dust caps. Tightened everything up nicely for about 10 bucks. You can pick that kit up from pretty much anywhere.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    rockauto.com
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Aug 19 2013
    minnesota
    Quote Originally Posted by agentsmith988 View Post
    Yoo da mannnnnnm
    Aug 19 2013
    minnesota
    Quote Originally Posted by eljay View Post
    rockauto.com
    Yoos da mans toos eh' I'm a RockAuto junkie, I'm so tired this week I can't even think straight, I should have known to look there. I Love AZ
    Aug 19 2013
    minnesota
    I've seen a couple of reviews about the brake stiffeningkit and the most honest and Frank one that I read said that there was no discernible upgrade. Just that it restored the stock sensation in the pedal. I think old guy said he really liked it. Anyone got reviews on it overtime? Is it worth it on b7s4 brakes?
    Aug 26 2005
    My experience with the stiffening kit is only with the stock 1.8T brakes. The kit provided a significant improvement in firming up the pedal feel, and increased the stopping power of the brakes enough to be worthwhile. The B6 S4 front brakes I am running with now, are easy to get into ABS activated mode, and I would not really want more sensitive or more powerful front brakes, since it would be a bit to much I think. The designers of the brake calipers know all about solid mounting of calipers vs using rubber bushings. The calipers are rubber bushed for overall less NVH with the brakes applied. The stiffening kit also exposes the guide pins to the elements, and is more likely to have problems with guide pin seizure with more maintenance required to avoid that.
    Jun 27 2011
    I also ran the stiffening kit and felt an improvement int he pedal feel. modulation seemed more direct and less spongy as you got into the brakes.
    Also with the flex in the rubber gasket thing being gone, your pads will wear more evenly.
    -CP
    2017 Q7 3.0t
    Aug 26 2005
    What brakes? Stock or?
    Jun 27 2011
    They were b6 s4 brakes. But it's the same kit.
    I suppose my experience doesn't directly translate due to the caliper being different but the brakes operate on the same slide pins so it should be similar.
    -CP
    2017 Q7 3.0t
