Results 1 to 7 of 7
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    Best Performance 1.8t Downpipe?
    So my stock flex joint died again. If I'm going to replace it, I might as well get something better than stock. Right now I'm on a stock turbo, stage 1+ tune, 034 HFC, stock cat-back. I'd like to eventually get an aftermarket exhaust too, so I don't want a downpipe that tapers down to stock size at the end. I'll just use an adapter in place of the clamp sleeve in the meantime. Price is definitely a consideration right now, but I'd really rather not do it again anytime soon, so I want something that's going to last.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    2019 SQ5 Prestige
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    If you change your mind I have a stock 5 speed dp if you need it.
    Dec 30 2014
    South Carolina
    EDIT : Stupid phone
    Aug 17 2015
    Evansville, IN
    PM sent.
    Feb 27 2011
    Winnipeg
    Techtonics is the best choice for off the shelf. I had a local guy make me a 3" stainless ones that tapers to 2.5" for the same price as the techtonics one tho and the price included install.
    Veteran Member Three Rings larry_fopps's Avatar
    Jul 29 2014
    MK3 2.9L Vr6 WIP
    Sayreville NJ
    Here's my setup. Very happy on the quality of the techtonics downpipes
    034 Motorsport High Flow Cat
    Techtonics Tuning Downpipe
    Magnaflow 16601 Cat back
