Results 1 to 3 of 3
    Aug 19 2013
    minnesota
    Washer pump O ring + ABS sensor screw part numbers please
    My headlight and windshield washer pumps are leaking where they connect to the reservoir. Also the head broke off the screw holding the ABS sensor on the front... Any one got a part number handy?
    For the ABS screw ECS lists 2 different ones for front and rear, front N0147346 and rear N01474011
    Still need oring size or part number for washer pump...
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Apr 15 2014
    Ottawa/Gatineau Canada
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Aug 19 2013
    minnesota
    Quote Originally Posted by Luxus Panzer View Post
    I called the stealership and they have them on hand. It's like a dollar for the screw and who knows how much for the o Rings. But I wanted to get new caliper guide Bolt caps and those were like 25 bucks.
