Results 1 to 13 of 13
    Nov 10 2013
    annapolis, md
    About to go Stage 2 but ....smaller AWE pulley/belt or JHM crank pulley?
    So I def want to go stage 2 as soon as GIAC has there next sale (anyone know when that might be?) and am wondering if I should go with the smaller AWE Pulley and belt for $495 or get the JHM crank pulley currently on sale for $395. It seems like both will get you to stage 2 levels with appropriate stage 2 software so I'm wondering which one makes more sense to purchase? A smaller pulley or a JHM crank pulley? I'm thinking the JHM crank pulley because it sounds like our OEM one is prone to break. Thanks for your comments in advance.
    2011 Deep Sea Blue S4
    7-speed DSG / B&O / MMI with Nav / Advanced Key / Carbon Atlas Inlays / Black Leather /19" Peelers/Push Button Start/Sport-Diff/Comfort Mode;)
    Modifications: Stage 2 GIAC w/Emmanuel Design Pulley, TCU DSG GIAC Tune, EuroCode Alu Kreuz, Roc Euro Intake, 034 Trans mount, Apikol mount, H&R front & rear sways
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Go dual-pulley and get both.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Apr 05 2016
    Portland, OR
    If you are going a smaller SC pulley just grab the CTS one for $160: http://www.ctsturbo.com/cart/product...-4793-688.html
    If cost is not an option I would go with a larger crank as that part is known to fail and it is less noticeable when you go in to Audi for work. (Plus it is easier to swap out
    Note: GIAC is pretty picky about what pulleys there tunes go on.
    They currently have a Beta Dual Pulley file but, I believe it is only for people with an AWE SC Pulley and GMG Crank Pulley.
    Geoff
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    You are looking at the wrong crank pulley. JHM has two crank pulleys,$395 one is the same diameter as stock, just lighter. You need to go for $450 one.
    If I were you, I would definitely go for crank pulley because replacing the crank pulley is a must, sooner or later. Or, just dual pulley. GIAC stage2+CW.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Dec 01 2013
    '93 RX-7
    San Francisco
    Quote Originally Posted by yjypm View Post
    I'll probably get to stage two after a few more track days. Why is replacing the crank pulley a must? Common point of failure?
    2012 S4 MT6 | Prestige | Sports Diff | Phantom Black Pearl | Black Optic Package | Titanium Package | H & R sport Sways | CR-15 | CTS Intake | EPL Stage 1 | 034 Track Spec Upper Control arms | 034 drivetrain/trans inserts | JHM Shifter
    Oct 08 2015
    Quote Originally Posted by SonnyDeez View Post
    It is one of the parts that are more likely to fail in the engine bay, especially after stage 2. The thing is, when the pulley fails it takes other things in the engine bay with it, which could lead to a huge repair cost. There are already several people experienced crank pulley failure over here.
    Current: '18 M3 ZCP
    Dec 22 2009
    MA
    Quote Originally Posted by whiped View Post
    Source? This is great to hear - first I've heard that GIAC is working on a dual-pulley file!
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Acejam View Post
    Email them, I will see if I can find the messages where people were talking about it.
    Edit: It starts around here somewhere: http://www.audizine.com/forum/showth...1#post11702606
    Only downfall is they are confirming that you are running their hardware. AWE SC and GMG Crank I believe is all they support.
    Geoff
    Nov 10 2013
    annapolis, md
    Does anyone know how much the GMG crank pulley cost? Also can anyone confirm if the JHM crank pulley will work with a GIAC stage 2 tune. Lastly what's the difference between the JHM pulley and the GMG pulley. I'm guessing size?
    Jul 21 2004
    South Florida
    Like whiped mentioned above I would absolutely call AWE first before you go buying a CP. They very well may require you to buy their proprietary stage 2 SC pulley in order to get their stage 2 flash tune. I believe their pulleys have registration numbers on them so they can confirm you have stage 2 (the one I had on my car had a 4 digit number). APR and GIAC can be sticklers about these details.
    Mike
    2018 Audi S5
    Gone-
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by z_curtis_s4 View Post
    JHM - 179mm
    GMG - 180mm
    Will JHM work with GIAC Stage II - yes
    but, you will want to get CW so you can avoid bleeding some boost.
    Tons more information here: http://www.audizine.com/forum/showth...lopment-thread
    Geoff
    Nov 10 2013
    annapolis, md
    SO 1 mm shouldn't be the end of the world between JHM and GMG. Has anyone just bought a JHM crank pulley and gotten the GIAC stage 2 software recently? Also you(whipped) talked about bleeding boost... if I got a AWE pulley and stage 2 software would it bleed boost like you say the JHM crank pulley will do? Not sure if I want to go the CW route.
    Apr 05 2016
    Portland, OR
    Sorry, I was talking about dual pulley setups.
    A single pulley with a ratio of around 2.8 shouldn't bleed boosts on Stage II tunes. (See the table in the thread linked above for ratios)
    I know of a few people running dual pulley tunes with GIAC. No one running only a JHM crank with their tune.
    My advice: Contact them and see what they can do for you.
    Geoff
