Results 1 to 4 of 4
    Oct 31 2013
    WA
    Any detailed instructions on how to remove TIP tranny in VAG-COM?
    I've read some instructions on the wiki and various DIY's, but missing the starting point. When the program comes up, what does "Cluster" mean and how do I get to "Adaptation"? Any videos or screenshots of this process? I'm assuming this will work Allroad with BEL engine the same way it works for S4?
    Thanks.
    From wiki:
    Ignition on but no start
    Cluster
    Adaption, channel 60, set to 1025 (removes Transmission from CAN Bus)
    Ignition Off
    ABS
    Use Tip login code : 07497, or 07397, 07597
    ReCode to 6spd : 06395
    Ignition Off
    ECU
    If recoding a Tip ECU
    Login with 11463
    Recode to 6spd : 06711
    Ignition off
    Ignition back on
    Clear codes in Cluster, ABS, ECU
    ECU Throttle Body Adaption
    Set Block channel 60
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    They look pretty detailed already to me.
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
    Sep 16 2010
    Central Wash
    "Cluster" is module 17- instruments. Go to the adaptations menu to make the changes.
    Oct 31 2013
    WA
    Thanks man, that probably sounds like a silly question, but when i was trying to scan through it quickly i was not seeing the specific "cluster" language on any button.
