Results 1 to 8 of 8
    Jul 28 2015
    Rochester, NY
    Is there a Timing chain write up / diy?
    Hello,
    I am getting ready to pull the motor for service. I plan on doing the timing while in there.
    i remember reading a DIY or something similar a few weeks back but I can't find it now... anyone have something? Just want to make sure I am not forgetting anything.
    Thanks,
    Current: 2014 Audi S4, 2005 S4
    Past: 2001 S4, 2006 S4
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    @Allowencer put together a great thread for the B8 section; maybe this is what you saw?
    http://www.audizine.com/forum/showth...hain+tensioner
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jul 28 2015
    Rochester, NY
    Thanks but this wasn't it. It was definitely for the 4.2 v8. I don't think it was on audizine... idk I just don't remember haha
    Oct 23 2014
    _
    Sorry, I missed that this was the S/RS section for the B7s; my bad.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Feb 18 2014
    Arizona
    The only online writeup I know of is the one for the engine pull, but it doesn't get into anything that is done after the motor is out. You can use the elsa or bentley manual for that
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    http://workshop-manuals.com/audi/s4_...fts/page_2592/
    Here's part of it that 2004b6S4 linked to my post. I believe switching out guides and tensioners are unbolt and replace
    Jul 13 2014
    1997BMWZ3
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by 2004B6S4 View Post
    Yep. There are a few threads out there if you search on what to expect at different points during the timing stuff, but no comprehensive write up for it. The Bentley does a decent job of it. I would recommend getting that (or elsa) at a minimum along with that engine pull guide.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
