Originally Posted by
hightime80
Yep your ecu is screwed. Try hooking up vcds see if it will communicate. If it does then use vag eeprom programmer to retrieve the skc then you can readapt another 02 ecu to it.
If it's a bit over your head try pm "k0mpressed" here on AZ. He runs his own tuning business and he is a whiz and he can probably hook u up with an immo defeated ecu in the worst case scenario.
Just chiming in with Troubleshooting tips I dont post much on here any more:
1) You had water in your ECM.
2) You had a "pop" occur when attempting to start car with associated smoke coming out of ECM.
3) Car no longer cranks.
Easy Solution:
1) Find and fix source of water leak.
2) Replace ECM with known compatible immo defeat unit from k0mpressed (or whomever)
3) Replace associated relays.
4)Check all fuses.
5) Start and drive car.
Thorough Solution:
2) Test ALL associated fuses, relays, and ECM - find whats bad . Dont forget the fusible link on the engine block.
3) Replace anything found not working in #2 above.
4) Replace ECM with immo-coded version to match your key fob if its bad.
All this towing... and starter swapping... and junkyard ECM swapping (without immo defeat) is absolutely time wasting and self-frustrating.
Keep it simple and focus on the problems that caused your issue.
Gud Luk.
