Results 1 to 17 of 17
    Dec 30 2013
    Australia
    Would 245 / 40 18" Fit a stock A4 B5?
    Namely:
    Wheels width - 18" x 8"
    Offset +43
    Center Bore - 57.1mm
    Does anyone have any pics?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    no
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 30 2013
    Australia
    scrub?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It probably could fit. But it is going to require a certain amount of spacers and/or fender rolling to get them to fit. There's people out there running 10 inch wide wheels. You can get anything to fit if you really want to. But they won't bolt up and go.
    2000 S4- Working?
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    At stock height you will probably have to worry more about spacers than the fenders.
    I ran 18x7.5 et49 with 225/40/18 with no issues. Still run them with coils on the car and only get some rubbing when turning on a hill.
    FYI with tires that size your speedo will be off about 3% on the low side (you'd be doing 58 when seeing 60)
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Yea 8 inch rims might be a little wide at that offset to clear the steering knuckle. Like red said, going to need spacers and probably fender role, might even end up going adjustable upper control arm route.
    right now i am running 235/45r17 falkens on a 17x7.5 45 offset audi a6 c5 wheel. luckily i cleared without rubbing the steering knuckle in front or spindle in the rear.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Willtheyfit.com
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I asked the same thing on an et35 wheel everything else being the same. It looks like 235/40/18 tires are best option to not worry about rolling fenders
    Dec 10 2013
    Borden, Ontario, Canada
    Are you guys serious? The only thing wrong with the wheel is the size of the tire.
    I'm running the B6 USP wheels and they're 18x8 et43. You want to run a 225/40r18 tire. You will clear with no issues
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Bordom View Post
    Which is why I said it wouldnt fit
    2000 S4- Working?
    Dec 10 2013
    Quote Originally Posted by redline380 View Post
    I thought you may have been doing that. I'm a little slow this afternoon haha
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I bought a set of the same wheel with 235 40 18's. Did not fit. Rubbed rear spindle.
    Dec 10 2013
    That's why you need the 225 tires. Slight stretch on the wheel won't hurt
    IG: 24_et
    Sold:
    RIP:
    Jun 10 2010
    245/40 is a little large, but will fit with spacers (fender roll/pull may be needed depending on vehicle height).
    235/40 is a good size, but will require smaller spacers.
    Aug 10 2015
    RIP 3000GT VR4 w/15g's
    Dorr MI (Grand Rapids Area)
    I run 245 35-18 with no spacers on a stock suspension. No issues.
    Dec 30 2013
    Australia
    Thanks for all your responses guys
    Dec 30 2013
    Australia
    Further, what stock 17" or 18" Audi rims fit the B5 without the need for spacers and/or fender rolling?
