Results 1 to 8 of 8
    Senior Member Two Rings Matthew_VA's Avatar
    Jul 05 2016
    Alexandria, VA
    Adding Additional Carbon Fiber Trim - dashboard/MMI surround - Thoughts?
    I love the carbon fiber trim in my new B8 S4 and was thinking of adding (a little) more. I've seen some older posts of the dashboard CF trim and/or MMI surround. But I'm not sure if it would be too much--there is that fine line between too much and just enough. What are people's thoughts on them? does it become excessive CF--has anyone installed them and had buyers remorse?
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I was between hydro dipping it CF and painting it piano black...ended up going piano black and couldn't be happier. I have CF interior and had the exact same thoughts and sided with it would have been too much CF.
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    A lot of people have done that piece in carbon. Really completes the look IMO.
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Can't really go wrong either way (as long as you match the carbon fiber). I bought the factory RS4 piano black piece and am very happy.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Senior Member Three Rings kpykng1's Avatar
    Feb 17 2016
    Ventura, CA
    I wanted to added a little more too so I just changed the shifter and that seems to hold me off...for now.
    2014 SQ5 Glacier White - 22" Touren TF01 - AWE Touring w/resonated downpipes - KW SC Coilovers - 034 Motorsports Rear Swaybar w/ endlinks, RSNAV System
    2017 MINI Cooper Countryman S
    Jul 05 2016
    Alexandria, VA
    Quote Originally Posted by jl87 View Post
    That looks really sharp!
    Jun 28 2016
    US
    Quote Originally Posted by kpykng1 View Post
    Where did you get the shifter? Looks like the ones listed on aliexpress... is that it?
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I painted the trim surrounding the gages on my 2010 satin black and liked it. Piano and gloss black will also work. BUT, I found the black trim quickly collected dust. I have learned to live with the silver color on my current 2011. IMHO, CF would not be too much
