Hey everyone,
I've been lurking around here for about 1.5yrs now, About the time I bought my s4. I just never created an account because I always found the results I need through Google search and I'm not a sh*t talker so I never had a reason to post. Now is the time though.
This car is my triple unicorn. Not only is it my first audi, but also my first turbo and awd car. I spent a lot of time studying me.7 coding and made a tune for the car which has been a blast but is also the reason this thread exists. I've shredded my stock clutch and I'm blowing oil out of more gaskets than not.
I am making this thread as a way to document my progress for myself and hopefully provide some incite for others, whether learning with me or from my mistakes. I am by no means an Audi mechanic but am well rehearsed in backyard mechanics ;) I'm also going to use you all as my drive. I see too many of these cars come apart then get sold or never put back together. I don't want that to be me and I feel like having others pushing you to see updates can be go motivation and reinforcement.
Enough of that. Onto what need to be done:
~Clutch is shot~ This car will be a weekend warrior. I'm retiring it from the daily life so I can get away with putting some obnoxiously large,stiff clutch in it that will hold all the hp in the world because I don't care about daily drivability.
~Oil leaks ~ Everywhere!!!! Definitely going to need valve cover gaskets and probably a bunch of other smalls as well.
~Coil conversion kit~ The stock coils feel pretty weak as of late. Lots of misfires under heavy boost. This should straighten it out.
~Exhaust leak~ Sounds like its right at drivers side turbo from engine compartment but could be further down the line
~Routine maintenance~ Check timing belt / tensioners /water pump etc.
~This is the line that all s4 owners know about where their 2week clutch swap becomes a 3yr big turbo conversion...lol...As much as I would like to have this thing on the road quickly, you never know what i'll do once the engine is on the stand!!!
DAY 1
Disassembly: I got a few hours before dark to tear into the car last night.
Here are the last photos of the car before disassembly
My survival kit for disassembly of the unknown
This looks like it could have been a boost leak. Ziptie holding in what I believe is an IAT sensor
Too dark shutting her down for the night
Should be able to get a couple more hours in this afternoon! See you soon.
