Results 1 to 4 of 4
    Jul 03 2016
    Johnsonville SC USA
    Audi 1.8 timing tensioner piston
    Piston won't compress. Any suggestions?
    Aug 26 2005
    It could take 5 to 10 min to compress the tensioner appling constant force. The tensioner must be compressed slowly in a vice, and the retainer plate that holds the tensioning rod in the tensioner body when fully compressed needs to ready to insert into the slot and hold the rod fully compressed. You won't be able to hold the tensioner rod compressed without the locking plate while you reinstall the tensioner to the block.
    Vorsprung durch Technik
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Mine went right in, but you have to do it slowly. Think I used a channel locks, or just pressed it down on the concrete using my body wieght
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Vice was the only fees-able method I could come up with and as others have pointed out it was about a 1/4 turn every 10 seconds or so.
