Results 1 to 9 of 9
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Lower control arm change - tightening procedure - unloaded or pre loaded?
    Lower control arms change, tightening procedure: tighten the bushing bolts (inner, and maybe the strut fork bushing bolt) with car on jacks (i.e. unloaded)? Or do they have to be tightened in the 'loaded' position (to reduce 'pre tension' on the rubber elements) on wheels or hub raised with jack for example?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    The consensus seems to be:
    Tighten loaded (i.e. sitting on its wheels)
    To avoid having stress on the bushings already in 'normal' setting.
    Somewhat mitigated with Allroad (what is "normal" setting; assuming level 2).
    Same applies towards upper control arms btw.
    05 Golf TDI
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Under normal circumstances, all suspension bushings should be tightened while suspension is loaded. Otherwise premature failure isn't an if, but when.
    That being said, I need replace my allroad components. The majority of my driving will be level 1 or two. Aside from an occasional off road adventure, or during a bad snow storm would I be any higher. Level 2?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    always load the suspension, its the factory procedure
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    so also if im gonna be low-ish the suspension needs to be at that geometry when tightened?
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by G Men 08 View Post
    Then you should lock in your bushing at level 1 or 2.
    I go with 2 (the systems default) and have 1 for high speed (still have NOT found a way to override the speed drop to level 1) and show and tell, with 1 'barely driveable'.
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by alien_brain View Post
    Naturally. But level selection for bushing 'lock in' is way more critical (one level to next can be 20mm) while playing with coil overs (once basic height established) is only a few mm up/down.
    "lock in bushings once final ride height and preferred main "level" is determined".
    Obviously: after major changes in ride height, the bushings can be 're-locked'.
    05 Golf TDI
    Jun 04 2013
    SE MI
    without affecting alignment?
    Feb 20 2010
    Brighton, MI
    Correct: Tightening the bolts of the bushings does not change alignment. Significantly raising/lowering and certainly messing with the tie rod DOES.
    05 Golf TDI
