Results 1 to 1 of 1
    Mar 05 2012
    11 Q5 2.0T, 18 Q7 3.0T, 89 Foxbody!
    Bucks County, PA
    AEM Methanol Injection Kit 30-3300 New with additional injector
    SOLD
    Selling my AEM Methanol kit that is new in box. 30-3300
    Also included is an additional nozzle kit. 30-3312
    Asking 375 shipped for the whole lot.
    Thanks!!!
    Boost Dependent controller features on-board MAP sensor with large adjustment knobs, integrated plug for harness connection, integrated fuse, covered status light and test button for enhanced splash resistance and mounting tabs
    Wiring harness is terminated with a positive-lock connector on one end with color-coded wires to ease installation, power and ground wires for the pump and additional wire for optional on/off fluid solenoid
    Internally-bypassed water/methanol injection pump does not cycle on/off and provides quiet, smooth operation; it features robust construction including integral hose fittings
    Three interchangeable injector nozzles to cover a wide variety of HP levels (250cc/min, 500cc/min and 1,000cc/min) 1 gallon tank with integral conductive low-fluid sensor and positive lock connector
    AEM's Water/Methanol Nozzle and Jet Kit allows users who require additional water/methanol volume to match their engine's requirements by adding an additional injector. This kit includes one precision-machined billet injector with integral check valve to prevent unintended fluid flow, three billet injector nozzles to match water/methanol flow to an engine's horsepower output, one foot (12 inch) of 1/4 inch nylon injection tubing and a T-fitting to integrate the additional nozzle into an existing system.
    2012 Q5 and 2018 Q7
