Whats up Cali Audi friends. I might be moving out to Comifornia and I am trying to figure out what I need to do with my car to get it to pass inspection. I am midway through my EFR install. Its a PAGparts EFR build which is in a stock location. I will be running a highflow CAT which is a really expensive quality one which can pass an emissions test. I plan to weld the stock CAT heat shields on it to make it look stock. So hopefully that will help with visual. I am also running a stock airbox with a 034 TIP. Its a silicon hose, will they give me grief for that?
Things I worry would not pass visual. Will my IE intake manifold pass or do I need a stock intake manifold?
I have a FMIC, will that pass?
currently have a UNI630 tune with my SIA coded out. Plan to shift to 1000cc injectors and Maestro. Will these pass the OBD2 out there?
I have no bypass valve anymore because it is onboard on my EFR. So I have that hole plugged in my 034 TIP.
I have an AEB head on my AWM. So I have no SIA setup anymore. Do I need to put that back on to pass visual. Will the AEB head give me problems?
For the EFR setup I am going to make a heatshield to try to cover my PPG manifold. I hope that helps fool them.
I also figure I need to get a stock engine cover again and the Passat Engine covers on the side to make it look as stock as possible.
Sooo thoughts?
