Results 1 to 8 of 8
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    3.0 AVK Loose screw inside timing cover- Where's it from?
    I found this tiny screw trapped inside my timing cover when I opened it up. Any idea where it's from? It's not one of the eight holding the VVT actuators in place.
    Nov 19 2006
    1994 Schwinn
    I'm wondering if it's from the backside of one of the cam gears, and if that means more trouble ahead...
    Nov 19 2006
    1994 Schwinn
    It's also not from the back of the cam gears- they're all in there, and they're larger. This one is maybe an M5 size.
    Registered Member One Ring 03a4b6quattro's Avatar
    Aug 27 2014
    2003 A4 B6 3.0 quattro
    las cruces/ NM
    Does it sound like you are dragging a trail of cans behind the car?
    Nov 19 2006
    1994 Schwinn
    No, no it doesn't sound like that at all.
    Jul 10 2015
    Colorado
    One of the bolts that attach the upper covers?
    Jan 09 2012
    MA
    What exactly do you mean by timing cover? The plastic covers over the cam belt?
    Nov 19 2006
    1994 Schwinn
    I actually think I noticed it when I removed the crankshaft dampener, and the lower timing cover. Now that I think about it, I'm not sure if I found it in the timing case or just sitting here, on the top of the upper oil pan:
