    Apr 07 2015
    Los Angeles CA
    GIAC Stage 2 no CEL no Boost!!!
    I need some and help and was not able to find anything on Audizine.
    Little background on the car:
    - Timing Belt/Head gasket replaced 5k ago
    - Most of the hoses and sensors replaced on the cooling system
    - Vacuum Line Replaced 5k ago
    - I have done a lot more work on the car but the things listed are pertinent to the problem IMO.
    First I thought it was my DV, but the boost is smooth and consistent through and through. There is no hissing or inconsistent noise.
    I should probably get a boost gauge to see what I am boosting at now. Feels like stock levels with added little extra from the exhaust and the HFC.
    Any info on this would help.
    My Set UP
    - GIAC 1+
    - TT 386cc Injectors
    - 034 HFC
    - AWE Cat back Exhaust
    - NKG BKR7E’s gaped at .04 with 2.0T coil pack (Might be the problem since most people run at .028 or .032)
    I got a CEL and my car does not pull nearly as hard.
    I am getting the P0171 Bank 1 System is too Lean
    Suggested to replace the crankshaft position sensor (which I did before the GIAC flush)
    Also it gave me two other possible codes that could be the cause:
    - P0102 MAF Sensor Circuit Low Input
    - P0411 Secondary Air Injection Incorrect Upstream Flow Detected
    Do you guys think it might be from NKG gaping? I cant imagine it is, because it ran like a dream for 179 miles.
    Please Help!!
    Oct 30 2006
    B8 A4 Avant 6spd
    Make sure you don't have any vacuum leaks, generally an engine will run lean if you have a fairly substantial leak. If you have access to vag com, go to 01 ECU - Measuring value block and see block 32.
    -18 718 GTS
    Apr 07 2015
    Los Angeles CA
    Roger that,
    I can only do this with the with Vag Com?
    I wen tot Autozone (they do free diagnostics) to get the the check engine checked out.
    Will report back as soon as I hunt down a Vag Com. Thanks!!
    Apr 07 2015
    Los Angeles CA
    correction, the spark plugs are gapped at 0.028
    Apr 07 2015
    Los Angeles CA
    Sorry took so long to update
    Here what was wrong:
    The MAF had to replaced
    The Breather Assembly is leaking
    And now my DV sounds like a DUCK under boost =(
    I just bought 034 Motor Breather Assembly and 710N DV and all New elbows hoses and everything else to replace the whole Breather Assembly.
    I hope to throw this on this weekend to prey to God I can start enjoying the GIAC benefits!!!!
