Results 1 to 4 of 4
    Active Member One Ring jrow96's Avatar
    Jun 28 2016
    Only one car..
    Kentucky
    Torque Converter
    I'm looking to replace my Torque Converter and when I pull it up on RockAuto it shows me one for $180, seems pretty cheap, can anyone confirm if this is the right one?
    2001 Audi S4
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Seems a bit low. Check out the RevMax torque converters. Otherwise I think Scotty from Advanced Automotion can help you as well. Get a good one with an upgraded seal so you don't have to mess with it again.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    Quote Originally Posted by jpurre View Post
    If you are swapping out the torque converter, please upgrade while you are at it. 517 and AA are both good options. I have 60k+ miles on my 517 TC and beat on it every time I drive it.
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    May 16 2008
    South Texas
    Do your homework with some of the discount converters, some companies don't upgrade the thrust bearings, or even address the lockup clutch lining. I've also seen some with leaky welds and poor balancing.
