Results 1 to 7 of 7
    May 21 2015
    Burlington . CANADA
    headlight lens opening
    I've been mulling over the idea of painting the inside of my headlight housings from chrome and changing to black. Scared of getting condensation in the lights once they are back on. Also never taken apart B8 lights and all the components attached.
    I assume it will be more of a challenge than my MK4 GLI but desperate to lose the chrome up front.
    Any thoughts?
    '15 Q5 TDI
    Technik
    S-Line/Monsoon/Blk Opt/B&O/KW V2/pano roof/H&R spaced/sq521"conti wrapped
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    I purchased a used, broken headlight assembly to open one up..... I have done several Retrofits on other vehicles... these things are permasealed which makes it much more difficult to separate the lenses.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2022 Audi Q8 3.0T Glacier White
    Mar 13 2014
    Newcastle, England
    As above these are tricky to do but they are possible to split.
    There is an SQ5 in Germany that has done what you want to do.
    Euro SQ5
    C6 Carbon Interior, Exterior and Engine Bay
    Custom yellow stitch and yellow seatbelts
    StillStatic/AH Exclusive Race H&R with custom Air bags (25" ground to fender)
    Aiflift 3P Management
    C6 Carbon Chassis mods
    DTUK Tuned 370Bhp 774Nm
    Rotiform DUS 22x10.5
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    If you're going to try, I'd go the same route as tcm glx did and find a used set ideally off a salvage or something.
    For what it's worth, the guys at ONEighty said they wouldn't do it after looking at mine, and they do all kinds of headlight customizations. It looks like a PITA to do based on what I've seen online. Here's an example: Audi A4 DIY Black Out Headlight Housings - AKA Joey Mod.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Anything is possible, but these may some of the hardest ones to attempt out there. Someone on one of the forums played around with an extra one and posted the pics of the process. After seeing his results, I definitely wouldn't do it on my new or only set (actually, I wouldn't try it at all, and I consider myself very competent with this stuff). Like ricenboy22 said, pick up some cheaper, used ones if you're going to attempt. They would look SO MUCH better blacked out a bit though, especially ecodes with all that clear/chrome.
    May 21 2015
    Burlington . CANADA
    This is more of what i'm thinking of. no red tho
    https://www.youtube.com/watch?v=cgk07RbYABQ
    '15 Q5 TDI
    Technik
    Mar 13 2014
    Newcastle, England
    Some pics of the set split in Germany.....and they are US spec also
    as an alternative mine are tinted with Lamin-x
    Euro SQ5
