Results 1 to 7 of 7
    Apr 15 2014
    Ottawa/Gatineau Canada
    Has anyone replaced the driver side door lock on a B6??
    If so, are our DS door locks something like this to replace?....
    https://www.youtube.com/watch?v=WndqgkLgT18
    Thanks
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Established Member Two Rings Shortrun's Avatar
    Dec 21 2015
    Ontario
    I can tell you the trunk lock on my B6 is like that.
    Also you need the key, or it will not come apart.
    Feb 12 2008
    Michigan
    why are you replacing the door lock? i pulled mine out because it was seized up and the key would not even go in it. soaked it in brake fluid a few days and then kept working the key in it trying to twist it up and free the frozen parts in the cylinder, after about tn minutes of working it it now works great.
    Apr 15 2014
    Quote Originally Posted by Fast4esT View Post
    I may be grabbing new doors and would want to swap in my lock cylinder from my old doors.
    May 24 2008
    cornish,me
    I've swapped out the door locks its very easy to do all you have to do is remove the black plastic plug adjacent to the lock inside the edge of the door loosen the small torx screw and pull the lock out.
    May 24 2008
    cornish,me
    I didn't look at the video yes that's how to remove the lock assembly is removed.
    Apr 15 2014
    Thanks all.
