Hi Guys,
Wanted some opinions on a recent issue I've been experiencing with my transmission. Vehicle is a 2001.5 B5 S4 6 speed manual.
Over the weekend I had an incident where I was unable to get the shifter into 3rd on a high rpm 2nd to 3rd up shift. I don't usually drive this car hard at all, but found it strange that it missed the gate that easily. (I'm not a newb by any means to driving manual as all my cars are manual and built in one way or another) so when I then rev matched as the rpm'S dipped from me holding in the clutch and got the car in 3rd no problem. My issue arised when I coasted to a stop and noticed I had no 2nd gear period. Shifter could not go in that gate and I wasn't going to force it. I also noticed I had no 1st gear or reverse. So I had to use 3rd gear from a stop, which I was no fan of. After letting the car sit for about an hour I went to check it out and I got 1st and reverse back but still no 2nd gear.
I can adjust the shift knob (left and right) and get 2nd gear back, but I lose reverse in the process and 2nd gear is really stiff. If the car is on a slant or incline 2nd gear is easy to get into?
Just wanted to gather some opinions on this situation before I go and possible swap out the transmission and or rebuild it.
Any input is greatly appreciated.
Thanks,
Travis
