Guten Morgen!
So I have had a very significant noise projecting from the rear passenger side wheel assembly everytime I drive over a bump. Sounds like a metal clank.
When I had the car up on our lift I notated a wiggle deviation of a 2-5CM on the tire and can reproduce the clank by emulating a bump in the road on the tire assembly.
Sounds to me like the bearings going kaput'
I've read through several guides posted on here about the procedure, it would appear the biggest hassle is using a press or like method to extract the old bearing assembly and to extrude in the new bearing to the hub mounts. Gotch'a
So I have two questions, After exhausting the search criteria on the site I am looking for links, suggestions on complete Rear Wheel bearing Kits from either Europa, ECS, etc. Any additional suggestions, installation or components would be greatly appreciated. Danke!
