Results 1 to 14 of 14
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    E85 ok to use with APR Stage 1 91tune?
    So I found a gas station that offers e85 but i hesitated when i was at the pump. Will this have an effect down the line like check engine /codes and is this compatible with my current tune. Thanks.
    Sent from my SM-N920I using Tapatalk
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    You should be able to run 5 gallons of E85 without throwing a lean code (fill up the rest of the tank with 91). Those who have gotten lean codes have generally been near ~ 40% E85; 6+ gallons.
    You'll make more power than straight 91, but will make more if you can load the 93 or 100 file- logging is advised on the race gas file to make sure your timing looks good.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    On my stage 1 I run 5 gallons with no issues
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    16 Gallon tank so roughly 3 to 1 or 2 to 1 ratio sounds like
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    I'm on the 91 tune currently (we don't have 93 here) and have been putting in 4 gallons of E85 over the past several fill-ups with nothing but positive results. I was also surprised to find MPG hasn't changed in my mixed city/highway heavy footed driving either. Car hasn't exploded yet so I'm looking to get the 93 tune and stick with 4-5 gallons mixed from here on out...
    I reached out to APR to get their take and of course they can't/won't say anything about it but I did confirm there is no added cost to go from a 91 to 93 tune, from APR at least.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Sep 08 2014
    Quote Originally Posted by grrrrrrr View Post
    the chevron off roxford and the 5?
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    interesting timing. I called GIAC about this today
    i can't imagine the tunes are drastically different and their recommendation is on par with the general consensus here. i'd be interested in hearing more people's experiences though
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Mar 27 2008
    Quote Originally Posted by Talor View Post
    yes. i think it was 2.34 last sunday.
    Mar 27 2008
    i just don't want to regret it in the long run as i have heard about the effect of corrosion in the engine. not sure if its true.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Oh man, what a misleading title! I totally thought APR released E85 files for a second there...
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Mar 27 2008
    Quote Originally Posted by Acejam View Post
    not my intention. apologies. updated title.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by LINDW4LL View Post
    I only have 91 octane here and usually mix 5 gallons of e85 but recently I threw a lean code for the first time with using only 5 gallons (threw codes before mixing more). I think the summer blend has a higher ethenol content than when I started mixing in the winter. So now I put 4 gallons and havent had any issues.
    Sent from my SM-G925V using Audizine mobile app
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    I'm not aware that e85 blend will make any more power than 91oct that is quality fuel on a 91oct file. If the timing is maxed out, no significant improvement would be had, i would imagine. It's true, ethanol will possible have a bit of a cooling affect, but I wouldn't imagine that it would be hugely significant. Anyone have a different opinion, and if so, explain???
    And yes, I did run a blend myself, but that was because I may have been pushing the limit of the file design and wanted to play it safe with knock prevention through higher octane, not because I was expecting more power out of a tune running the hardware it was designed for.
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Quote Originally Posted by OnEaNgRyBuNnY View Post
    I agree. E85 allows you to run more timing and more boost before knock threshold is reached and has a nice cooling effect. It doesn't make power by itself only when you tune to take advantage of it. In my turbo cars I can run sometimes an additional 10psi before I get any knock. Summer blend is closer to true E85, winter blend is more like E70. I learned this the hard way when I torched a head on my Eagle Talon running 40psi on a 65lbs/min turbo safely on the summer blend. September came along with the winter blend and BOOM! Lol. Winter blend I have to reduce timing to 15dg flat at peak torque.
