Results 1 to 21 of 21
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    What Tools Do You Keep in Your B5?
    So I got stuck at the gas station yesterday with a broken ground terminal at the battery.
    It was weird because car ran fine when I pulled in, but then wouldn't start after filling up. Anyway, it was after searching the entire car that I realized that I had nothing with me to fix it. I was able to just stick it back on and use the stickiness of the heat shrink to keep it in place till I got home. A zip tie would have been awesome.
    But this got me thinking that I need to put together a small tool pack for the car. As all I had was a tiny flat head screwdriver that I use to adjust my amps. Zip ties are now in as well.
    So what's in your car?
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    AAA card. And a basic socket set.
    Established Member Two Rings pgiuliano98's Avatar
    Jun 22 2015
    Livonia, New York
    My toolbox, mini jack, and jack stands. I rarely work on my car at home because of my gravel driveway so i usually keep all my tools in the car.
    May 22 2010
    N.E. Connecticut
    Quote Originally Posted by Davdraco1 View Post
    ^^ This ...
    Oct 31 2015
    Victoria, BC
    ^^ This ...
    Ya, I do have CAA/AAA. But I always feel this is a last resort.
    Build Thread HERE
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yup, AAA and a cell phone is all you need.
    Keeping tools in your car is a slippery slope, as is spare parts. You start with basics, and then before you know it you are riding around with a spare coolant flange and a hub tool for doing wheel bearings on the side of the road.
    No, I'll just tow her home if needed. I upgraded to Gold AAA so I get 100 mile tows. .
    On a side note, that battery looks exactly the same as my Bosch batteries. Where did you get it?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by Pringle420 View Post
    Why you pay for 3 tows a year. Better off using them when needed vs paying for something you don't use
    Established Member Two Rings jsbs1991's Avatar
    May 19 2014
    cbr 600f3
    Snellville GA
    i have a jack, and socket set. I usually have Audi coolant, oil, and chf11s because of steering rack leak.
    1999.5 A4 1.8TQ APR III, Ecs diff mount, apr snub mount, raceland ultimos, forge splitter.
    Oct 31 2015
    Victoria, BC
    I also have the Gold which gives me 200kms of towing. I really carry it because if my truck breaks down at the lake (180kms from door), I can get it home.
    I'll start with zip ties and CAA/AAA.
    As for the battery, it came with the car. But it is a Canadian Tire Motomaster Eliminator branded battery. But it could very well be a rebranded Bosch.
    Build Thread HERE
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    A 6 in one screwdriver and a pliers. Anything beyond that chances are she ain't moving anyway lol.
    Sep 12 2008
    South Central PA
    Only thing I can think of that isn't in my travel bag is the headbolt tool. I even keep the spare compression tester in the bag.
    It's good to keep a small set of tools in all of your vehicles, Harbor Freight is having a sale at the moment, you can get a small 35pc set with case for $10. I walked through the local HF today and picked up one for the fuck of it. It's better to have a chincy socket set that will help the 3 times you may use it, vs having to potentially get towed.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Oct 10 2013
    State College PA
    I don't pay for my AAA, it's a birthday gift every year.
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I keep the basic tool kit that came with the car with the oem jack. When i get stuck on the side of the rode the kit has bare essentialls to check things out. Also a little flashlight or cellphone light is good.
    Nov 07 2010
    South of Heaven
    I am not sure what comes in the tool kit but that is what I carry with me. I used to have CAA/AAA and it was paid for and the only time I used it was to get other peoples cars towed. The account was tied to my fathers and when he passed on I started to foot the bill myself. After a while I looked back over the decades and found I had never used it for any of my cars and killed the membership. Since that time I had my Corrado towed once for a failed slave cylinder and that has been it, I had a coil fail on my 1.8T but I could still drive and the MAF fail on both the A4 and Corrado but I could still drive both. So in 20 years I had never had the need for it but once so I didn't feel it was worth keeping.
    You know how I do this? I maintain my own cars and usually catch things just as they are getting bad or well before it. My car is a BT car and I drive it hard so the oil gets a workout so I usually change it around every 4,000 kms and it is pretty dirty. I run copper core plugs and they don't have the greatest of life so I change these every 4,000 kms with the oil. I also rotate the tires at the same time and take a good look at them. While the wheels are off I inspect the drive line and brakes and make sure nothing is starting to fail or leaking. I check the hoses under the floor of the car on each side and then check for new damage or damaged/aging rubber hoses. I check all around the bottom of the motor when I am draining the oil and replacing the filter and check for new leaks or other issues. On the top side I remove all of the plugs and read how the motor is burning over that interval and check all of the vacuum system. This time I found some oil on the turbo return line so I will need to check into that and one of the hose clamps on the evap return line. I also check the oil once a week and which time I check the other fluids and I run a skid plate so I can easily see if a leak is bad enough to start dripping down. Because I maintain my cars I never have the need to carry tools with me and I never worry about driving them anywhere.
    Obviously you don't care about that but if you maintain your vehicle and fix things as soon as the problem appears you will have less need for tools If you want a siggestion I would carry at least this off the top of my head...
    - Metric socket set with a few extensions
    - Small breaker bar
    - Metric wrench set
    - Matric Allen wrench set
    - Wire cutters
    - Wire strippers
    - An assortment of butt connectors and wiring for temp repairs
    - A few assorted pliers
    - A few different screw drivers
    - Triple square for the driveshafts if you have recently had them off
    - Coil(s) for the 1.8T
    - A few different vice grips
    - Varied size zap-straps
    I am sure I am missing a bunch of basic things but if you had those tools you would be able to do most repairs as long as you didn't need parts. No matter what you carry there will be that one time when you didn't have something so you end up failing in any case but at least you have a chance. Something simple could stop the car from safely driving and unless it was in the OE tool kit I would be screwed.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    It deepens on what my driving plans are. if i'm staying local normal driving I carry only whats needed to change a tire + zip ties flashlight duck tap and tire plug kit. all this other than the jack fits were the CD player would normally be. Light weight jack is on that list because OEM one is a widow maker.
    If im going on a trip ill take a tool bag that has all the right tools to pull the motor just about and jack stands so if I really need to I can fix her on the fly.
    If im going to rally x I take just about everything + 5 qts oil coolant power steering ect. one day I'll have a truck and trailer so if it brakes I can just load up and tow it home.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Feb 27 2011
    Winnipeg
    long road trips I keep coolant, oil and ps fluid in the trunk along with spare ICM and coils, bluetooth OBDII reader, socket set with hex and torx bits. Have lost an ICM in the middle of northern Manitoba with no cell service so I keep a few lol. Around the city I have CAA and a cell phone and I'll just get it dragged back home.
    Jun 25 2015
    California Hawthorne
    AAA card, cell phone ,HF aluminum jack, a small tool bag with as many hand tools stuffed in as can fit and oil and a empty jug. something breaks on a weekly basis
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Nothing. Whatever comes in the box with the jack. So a screwdriver? And jumper cables. That's it.
    Jumper leads oem jack and audi tool kit a multi pack of fuses you can be surprised that one fuse can stop a hole car. Bulbs in case of one failing and a funny old copper pulling me over. Electrical tester and metric socket and ratchet multi screw driver with various bits and a tow rope got my own aa service (dad)😊
    Sent from my SM-G903F using Tapatalk
    Junior Member One Ring
    May 28 2016
    Phoenix
    Once used a coat-hanger to fix a broken throttle cable at the pedal. Tied and bent it around the broken end and looped it around the gas pedal. Albuquerque to Phoenix. Wouldn't go over 60 mph but I think the top speed on that 1974 VW Dasher was under 70 anyway.
    So when unexpected things happen, you need unexpected tools and materials for repairs. And 90 percent of the time you're helping someone else, right?
    Don't forget you can sacrifice other parts on the car to get you going. The guy who lost all five lug nuts off one wheel? Tell him to take one nut off each of the other wheels and he'll get home just fine.
    Apr 02 2013
    above top secret
    Apart from the OEM jack and basic tools from Audi, I kept the following:
    i) A set of cheapo 1/4" hex socket with variety of screwdriver/allen/star bits
    ii) 1 liter of distilled water
    iii) 1 liter of engine oil
    iv) Jumper cable
    v) Extendable lug wrench or extension pipe
    vi) Electric air compressor/foot pump just in case your spare wheel is overlooked when needed
